Author Topic: MAME Driving Cabinet help please  (Read 2328 times)
Johnny_Summers
  • Last login:April 05, 2006, 06:51:08 am
« on: March 08, 2006, 06:57:57 am »
Hi guys,
Just joined the forum.
I already have a standard (JAMMA spec) MAME cabinet, but as you can imagine, playing driving games on one of these just doesn't do it.
I have managed to get hold of a Special Criminal Investigation cab with the view of playing the MAME driving games on it. Upon investigating the controls for the wheel, they seem to be similar to that of a (non optical) mouse (wheels with holes in it, sensors at the side for the x-axis).
My question is.......can I wire this up as a mouse and use it directly in the PC (serial or PS2) or would I need an Opti-Pac, A-Pac etc?
Also, if anyone has any manuals or documents for this machine that would help with identifying wiring etc I would be extremely grateful.
Cheers guys,
Johnny.
Re: MAME Driving Cabinet help please
« Reply #1 on: March 08, 2006, 09:23:05 am »
You could almost certainly wire the optics up to a mouse hack, opti-pac or similar interface...this is common practice, search this board for more info.
Failing this, you could use a mouse hack, but use the mouse optics instead of the original arcade ones...do this only if the above does not work tho.
Johnny_Summers
« Reply #2 on: March 08, 2006, 10:08:28 am »
MinWah,
Thanks for the reply. Can I just confirm:
Using an Opti-Pac, I wire up from the wheel (4 wires IIRC) to the Opti-Pac board, then use the standard PS2 cable from the Opti-Pac board to the PC. Using a mouse, I chop the mouse bit off and connect directly to the wires coming out of the steering wheel? If that is the case, what is the advantage of using an Opti-Pac? Oh, the Opti-Pac handles the buttons I guess?
Thanks again.
Johnny.
« Reply #3 on: March 08, 2006, 11:00:31 am »
Yep.
Not quite that simple, see: http://mamewah.mameworld.net/mousehack.htm
Basically an Opti-Pac is a piece of cake to connect up to, a mouse hack is not (Oscars pre-hacked mice excluded, but these are currently unavailable).
Johnny_Summers
« Reply #4 on: March 08, 2006, 11:28:06 am »
Minwah,
Thanks very much for that info. I actually already have an Opti-Pac so I will give it a go with that.
Johnny.
« Reply #5 on: March 08, 2006, 11:32:17 am »
Good luck, you just need to identify the 5v and GND wires then and you should be set :)
