Author Topic: Different control setups?  (Read 1273 times)
niterider
  • Last login:July 19, 2006, 08:22:42 pm
« on: March 05, 2006, 12:13:20 pm »
I've got a Virtua Fighter 2 cabinet that the monitor works fine, but the boards (it came with four games) all have some problems so their not playable.
I'm considering using this cab for a MAME machine, but I would like to do more with it then just the standard "2 player-6 button" layout.
What I would like to do is set it up so I could play a 2 player light gun game like Area 51 or go to a racing game like Pole Position with a steering wheel and gas/brake pedals.
Does anyone have a setup that sounds like this?  I'm looking for ideas on how to do this, products (guns, steering wheels, ect) to use, or just suggestions for anything else that would be cool to add.
Thanks for your time.
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
Re: Different control setups?
« Reply #1 on: March 05, 2006, 05:08:48 pm »
hiya niterider,
You have a few options if you decide to go this route.  You could either use swappable panels (which I had at one point).  This would allow you to replace the entire top part of your control panel.  A more flexible (but more work of course) is to have a modular panel.  This is what I have now and I am very happy with it.  If you are only planning on swapping in guns and steering wheels you could possibly just add a USB socket on your panel and come up with a way to clamp the steering wheel to your single panel.  Lots of options and probably even more.  Give the forums a search for terms like "swappable" or modular and you'll find a few cool projects/ideas.
have fun,
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
niterider
« Reply #2 on: March 05, 2006, 05:29:09 pm »
I like how you have yours setup.  Thats a pretty neat idea.
I was thinking of doing something about what you did, but I was going to go with something more general. Sorta like using just three or four different setups that and that would be it.  I'm considering mounting a couple of light guns to either side of the cabinet and then just having a steering wheel panel, a standard "fighter" panel, and a "classic" panel (pacman, galaga, dig dug, ect) with a spinner and a trackball that I could switch out.
Thanks for the info.
