Author Topic: Which router bits do I need?  (Read 5943 times)
« on: March 02, 2006, 12:21:18 pm »
Hey guys - I am in need of a couple bits. Could someone confirm if these are the bits I need:
1st bit is intended to be used to trim the plexiglass/lexan.
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_flush.html
If yes - does the cutting length matter between a 1" and a bigger size? The Plexi will probably only be 1/8
2nd bit is inteded to cut the 1/16th in slot for the t-molding
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html#Anchor%20slotct3w
My router accepts 1/2" shank.
Thanks, I appreicate the help. I'm very much a rookie with this woodworking.
Fozzy The Bear
  • Handbags at dawn in here!!!
Re: Which router bits do I need?
« Reply #1 on: March 02, 2006, 12:28:05 pm »
The first one is fine Lew.....  But I can't see a slot cutter on the second list that has a 1/16 cut height.  The right sort of cutter, just not the right thickness of cut.
Personally I use a 16th" biscuit cutter....  They're used for cutting a slot to take a glue in jointing biscuit in furnature making.
Best Regards,
Julian (Fozzy The Bear)
« Reply #2 on: March 02, 2006, 12:30:40 pm »
Best Regards,
First bit good - thanks.
As for the second bit - I was thinking in the lower table, top right under 1/2" shank is set #7641
Fozzy The Bear
« Reply #3 on: March 02, 2006, 12:50:08 pm »
Yup! You're right.... I see it now.... Doh!!!  ::)
Yes, that should do the job.
Best Regards,
« Reply #4 on: March 02, 2006, 01:11:41 pm »
Awesome! Thanks for the help Foz...
order placed
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #5 on: March 03, 2006, 02:29:01 am »
Too late now since you've already placed your order, but you shoulda gone with the 1 5/8" or 2" version.  You could do more patterns or whatnot, and the amount is minimal compared to the entire line.
If you weren't concerned with patterns, that shear-cut bit below that first bit would have been a nicer bit to buy.
