Author Topic: Oscar Controls Spinner Question?  (Read 983 times)
Deefish
  • Last login:September 01, 2025, 12:33:47 pm
  • Is there something in my teeth? Look close.
« on: March 02, 2006, 11:40:45 am »
I have an Oscar Controls V1 Spinner for metal CP. It came with two plastic/nylon spacers for above and below the CP. I had to remove the top one due to mounting it on a wood panel. My spinner wobbles now as the collar that is mounted in the plate does not hold the shaft tight. How can I fix this? Can I add the sealed bearings to make it straight and also spin longer? I was wondering if skateboard wheel bearings would work if I get the right diameter?
thanks,
deefish
