Author Topic: Error's with Mamewah times  (Read 1254 times)
POS
  • Last login:March 22, 2006, 01:31:02 pm
« on: March 01, 2006, 04:20:09 pm »
Here is what happens when I execute Mamewah.  I included the system files as well:
3/1/06 1:20:43 PM MAMEWAH launched
3/1/06 1:20:43 PM Desktop colour: 8421376
3/1/06 1:20:43 PM Wallpaper filename:
3/1/06 1:20:43 PM Display mode: 1024x768 @ 0Hz, 24 bit colour
3/1/06 1:20:43 PM Decimal symbol: '.'
3/1/06 1:20:43 PM Error: 75 Path/File access error in INI_SaveConfig
3/1/06 1:20:43 PM Error: 75 Path/File access error in EMUINI_SaveConfig
3/1/06 1:20:43 PM Error: 75 Path/File access error in LISTINI_SaveConfig
3/1/06 1:20:43 PM Games list read: mame-0.lst
3/1/06 1:20:44 PM Layout selected: C:\MY DOCUMENTS\ARCADE\ARCADE PROJECT\MAMEWAH_V161\layouts\Classic 640x480\layout.lay
3/1/06 1:20:44 PM Bad image file: C:\MY DOCUMENTS\ARCADE\ARCADE PROJECT\MAMEWAH_V161\layouts\mamewah-art.png
3/1/06 1:20:44 PM Ctrlr file selected: C:\MY DOCUMENTS\ARCADE\ARCADE PROJECT\MAMEWAH_V161\ctrlr\default.ini
3/1/06 1:20:50 PM Error: 75 Path/File access error in INI_SaveConfig
3/1/06 1:20:50 PM Error: 75 Path/File access error in EMUINI_SaveConfig
3/1/06 1:20:50 PM Error: 75 Path/File access error in LISTINI_SaveConfig
3/1/06 1:20:51 PM MAMEWAH quit
I'm sure it's somthing simple, I just can't seem to find the answer isn doc's
Re: Error's with Mamewah times
« Reply #1 on: March 02, 2006, 07:10:44 am »
Not sure about that one (although you should be able to fix the bad image problem).
Try the latest beta from the ArcadeOS/Mamewah board at MameWorld and see if it does the same.  Install it to a fresh folder though so not to lose your current settings.
