Author Topic: I-PAC vs KeyWIz Max  (Read 2896 times)
njclifford
  • Last login:December 18, 2007, 10:40:55 pm
I-PAC vs KeyWIz Max
« on: February 27, 2006, 06:23:25 pm »
Morning, 1st post so BE NICE!!!!!!
I have read all the associated articles on the differences etc... but in the article I was reading it only mentions KeyWiz vs I-PAC 4 . Now the MAX has PS-2 for keyboard and other features, what are the main differences between these two and what do most people prefer?
Down in Oz, it is cheaper to get the KeyWiz Max.
Also, is there a list of Games / Inputs needed.... am think of a 2 x 4way and 1x 2 way control console and want to see what games I am limited to.
THANKS!
Nick
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
Re: I-PAC vs KeyWIz Max
« Reply #1 on: February 27, 2006, 06:40:24 pm »
I refer KeyWiz. It comes with MAME default on the rocessor. The keyboard switch also makes it easier, and its $5 bucks cheaer
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #2 on: February 27, 2006, 06:46:49 pm »
Go with the Hagstrom stuff.
I just wanted to throw that monkey wrench in there since I've been looking at them lately ;)
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: February 27, 2006, 07:13:11 pm »
I am going to be nice, but you definitely HAVEN'T read all of the associated articles (you dirty fibber!)... check Tiger-Heli's guide for the answer to most, if not all, questions.
http://www.mameworld.net/tigerheli/encoder/index.htm
Not sure why USS Enterprise cites "MAME default on the (p)rocessor" as an advantage over the IPac, but to each his own.
For the functionality that you are looking for, I suspect that you would be happy with either, although I may be confused as to your intentions since I have never seen anybody put a 2-way stick on an emulator cabinet (although I like the idea, I suspect that you meant 2-8ways and a 4-way).  ;D
Welcome to the boards and forgive me if I seem to be throwing you into the deep end with nothing but some smart@$$ comments ... it's been a whole two days since this question was last asked.  :angel:
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
markrvp
  • NFL Expert
« Reply #4 on: February 27, 2006, 07:14:44 pm »
He's being silly.
Read the article by Tiger-Heli that CheffoJeffo linked.  Both are good products that will serve you well.
njclifford
« Reply #5 on: February 27, 2006, 08:32:31 pm »
I am being silly.  That is the article I did browse through but obviously not well enough!
Thanks for that... I will read in depth before posting.....
I am a noob!
N
USSEnterprise
    • USS Odyssey
« Reply #6 on: February 27, 2006, 09:06:00 pm »
I didn't think the iqac had the default MAME keymaq in its ROM.
My #Synonym fors also bad urinate# key doesn't work. Even worse, backsqace is also bad
CheffoJeffo
« Reply #7 on: February 27, 2006, 09:16:25 pm »
Quote from: IPac FAQ
Do I have a lot of setting up to do before playing?
NO. Using the key-code programming is entirely optional. When the board is shipped, all codes are automatically assigned to MAME standard keys. As many people have found, this makes installation very quick and easy.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
markrvp
  • NFL Expert
« Reply #8 on: February 27, 2006, 09:39:01 pm »
Quote from: USSEnterprise link=topic=50761.msg495784#msg495784
[/quote
What is an "iqac"?  It sounds like something a duck would say.
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: February 28, 2006, 07:25:48 am »
I can guess what is going on here - First off, the I-PAC/2 and KeyWiz both support the MAME default set out of the box.  (Neither supports P2 buttons 5-8 b/c MAME doesn't define defaults for these, so you have to manually set them, but that is a MAME issue, not an encoder issue.
The I-PAC/4 has a lot fewer inputs defined, mainly b/c MAME failed to define these.
The KeyWiz does define a lot of useful keys such as P (Pause), Esc, Tab, and Enter, hard-coded, but it has four extra inputs to play with.  OTOH, the I-PAC can be re-programmed as desired and will retain it's settings, and the KeyWiz will need to be re-programmed from a startup file if you don't use the default codeset.
BTW, short and sweet comparison is here: http://www.mameworld.net/tigerheli/encoder/main.htm#KeyWiz_vs._I-PAC2 but you will likely need to read a lot of the rest of the article for definition of terms.
Lilwolf
« Reply #10 on: February 28, 2006, 08:22:02 am »
One advantage that was mentioned is that IPac keeps its settings between reboots.  (it was mentioend that keywiz needs to be setup everytime... samething).
this is a very nice feature.  ESPECIALLY if you plan on using a non-supported OS (dos/linux ect).  So you change it in windows, and then reboot into the other os.
but after all this, I never use it anymore :)
I have both, and like both.  I think keywiz are product lines are more active right now.  Randy is looking at new possibilities and building boards on them.  But even then, APacs are pretty new and cool item.
So all in all... buy one of each and build two cabinets :)
Havok
« Reply #11 on: February 28, 2006, 08:29:12 am »
Everybody always rags on the Keywiz for not saving settings. Why don't you do what I do: program MAME to use the default settings of the KeyWiz? There - no worries about reprogramming on boot. Done.
Tiger-Heli
    • Tiger-Heli
« Reply #12 on: February 28, 2006, 10:22:08 am »
MAME already uses the default settings of the KeyWiz ;D
I use the KeyWiz and almost never reprogram it.
The point was if say you mainly play ummm - let's say Golden Tee PC on your cab, and it won't allow you to change key assignments, and they don't match the KeyWiz defaults, the KeyWiz is SLIGHTLY less convenient (more so if you hot-swap it) than the I-PAC.
Havok
« Reply #13 on: February 28, 2006, 11:09:20 am »
I refer you to Player 2 controls!
 :P
Golden Tee PC on my cab? Blasphemy!
However, I do concur with your point there, Randy..
Errm... Tiger-Heli.
 :D
Tiger-Heli
    • Tiger-Heli
« Reply #14 on: February 28, 2006, 11:15:37 am »
 :P
Errmmmn, yeah, I just posted that (Reply #9) this morning.  It's hell getting old . . .
    • GroovyGameGear.com
« Reply #15 on: February 28, 2006, 11:59:49 am »
 :P
That's a MAME thing.  Until they change the defaults to not use joystick buttons for the higher numbered buttons, you'll need to change it no matter what.
Or did I miss your point?
