Poll
How would you finish a basement's ceiling?
Drywall
7 (30.4%)
Drop ceiling
12 (52.2%)
Tiles
2 (8.7%)
Other (Please explain)
2 (8.7%)
Total Members Voted: 23
Author Topic: How would you finish a basement's ceiling?  (Read 5324 times)
GGKoul
  • Cheesecake Apprentice
  • Last login:May 26, 2024, 02:06:23 am
  • I was once a big man!! -4700 posts later...
« on: February 27, 2006, 10:26:52 am »
Hello
I'm just about to start finishing my basement.  Phase 1 of course is to start the framing process.  But before I start, I need to decide how I want to finish my basement ceiling.  And I've been told to insulate the joists and then drywall the ceiling.  But then I'm stuck with whatever wiring I run before hand.
But if I tile or put it a drop ceiling, then I'll have access to drop other lines as required.  But it that worth the added expense and effort puting that in?
What do you think?
Thanks!!
-GG
ErikRuud
Re: How would you finish a basement's ceiling?
« Reply #1 on: February 27, 2006, 10:39:49 am »
In my basement, the main duct runs accross the back of the basement.  There is a roughly two foot wide area between the ductwork and the back wall. Almost all of the main wiring and plumbing runs were move to that two foot area and then that area was done as a drop ceiling.  The rest of the basement was done in drywall to keep the ceiling height as high as possible.
American Laser Games Wrapper
O2em Rom Utility
« Reply #2 on: February 27, 2006, 10:42:30 am »
I'm doing mine with a custom drop ceiling between the joists, not under the joists.  Need to maintain access to the stuff in there.
GGKoul
« Reply #3 on: February 27, 2006, 10:48:09 am »
Interesting.  Any pics?
« Reply #4 on: February 27, 2006, 10:50:25 am »
No, the work is not underway yet.  Basically, put some trim pieces in between the joists and then cut some thin plywood tiles to fit.  Ceiling height is an issue in my basement.
menace
« Reply #5 on: February 27, 2006, 11:04:25 am »
just as an alternative i've also seen the interlok ceiling tiles used and stapled to a 1x2 strapping nailed to the joists--your height losses are a lot less than drop ceiling but if you need access you can pull down the offending tiles and replace with new ones--i'm considering this for our new place.  They are also textured which adds a little to the room architecturally.
GGKoul
« Reply #6 on: February 27, 2006, 11:17:13 am »
I was thinking about that too.  My buddy did that, but he said it was a lot of work!!
fredster
  • Grand Prophet of Arcadeology
  • Last login:February 16, 2019, 04:28:53 pm
  • It's all good!
« Reply #7 on: February 27, 2006, 12:07:47 pm »
What does the ceiling look like now?
Can you just leave it and maybe paint it all?
King of the Flying Monkeys from the Dark Side
dmsuchy
  • Last login:August 29, 2025, 01:27:50 pm
  • I kill communist llamas for fun.
« Reply #8 on: February 27, 2006, 12:24:21 pm »
I drywalled mine, I first replaced all my plumbing with copper and ran a crap load of spare speaker wire and cat 5 up there. Than drywalled with a bunch of 4" cans. Makes the basement seem less like a basement. If I ever did have to run more wire, cutting access holes and patching them isn't a promblem. I have a couple of shots of my basement under the project ann. section, under RoboMame.
GGKoul
« Reply #9 on: February 27, 2006, 01:25:24 pm »
I'll take some pics tonight
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
« Reply #10 on: February 27, 2006, 01:36:56 pm »
I'm going with drywall, but the wiring guy in me says that's bad.  So I ran PVC pipe from/to the locations where I might need some expansion.  I can just snake any wires I need down there.
My basement has one side that is all wiring, plumbing, etc.  So I ran conduit from there to the TV area, the bar area, the bedroom area, the patio (outside), and the pool table area.
Plus, I have soffits almost around the entire perimiter, so those conduits go into those soffits, so I can go in any direction once I get the wire out.
Jacktucky
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
CCM
« Reply #11 on: February 27, 2006, 02:25:40 pm »
My basement had a drop ceiling when I moved in, I have ripped that down and put up drywall.  I've never liked the look of drop ceilings.  If you plan well and run all the wires you need you shouldn't have a problem with drywall.
mccoy178
  • Go Bucks!
« Reply #12 on: February 27, 2006, 02:45:43 pm »
I am currently installing a drop ceiling as we speak.  I decided on that because I have the room, and I can ;).  I like the abiliity to fix a pipe or run wiring if needed.  I bought some nice 2x2 Armstrong tiles to not look like an office space.  The cost is a ton higher than drywall, and it's not as fun as drywall to install.  I have the DeWalt self leveling laser, so setting the brackets will be simple.  I have some oak left to finish around the glass block and the header, then full installation will begin.
boykster
  • The cake is a lie!
« Reply #13 on: February 27, 2006, 03:43:11 pm »
I dont think I've ever seen the words drywall and fun used in the same sentence before ???
Anyway, I chose the drywall for the same reasons as dmsuchy....if you plan ahead (run wires/etc) you don't have to worry too much about future-proofing.  If necessary, built soffits or run conduit.
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
« Reply #14 on: February 27, 2006, 03:50:49 pm »
Tiling is easy access!
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
mccoy178
  • Go Bucks!
« Reply #15 on: February 27, 2006, 04:51:12 pm »
I think it's fun because you have the opportunity to get down and dirty in the construction of it.  I had a pool installation company, and I guess I've always loved the hands on approach when building stuff.  Drywall let's you cut and measure and all kinds of neat stuff.  Sounds childish, but that's the only way to look at it in my opinion, otherwise, it would really really suck.  I've finished two basements with drywall ceilings now and I use Jedi mind tricks to get me motivated.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #16 on: February 28, 2006, 07:12:54 am »
A drop ceiling can be done so that you leave just enough room to move tiles if you ever need to access stuff, which would cost you about 2" in headroom.  The downside is loss of headroom and the look, which some folks don't like.
Drywall can be done so that all you lose is the thickness of the drywall.  The downside is the wiring issue you speak of, and possible leaks in your plumbing.
If the plumbing leaks, you'll be ripping the drywall down anyway, but you'll prolly have to replace ceilig tiles too, so I think that's a wash.  The major difference is the repair work needed if you find you DO need to run more wire.
Cut BETWEEN the joists and cut out a chunk at either end of your wiring run.  When you're done, you screw the chunk back up onto the ceiling (you WERE careful and not going Neanderthal, right? ;) ) and mud the piece back into place.  Not that hard, and if you put some effort into it to make it look nice, you'll never notice the area you cut out.  Using a fish tape would make even less of a repair hassle, but it's been my experience that people can't figure out how to do that type of "arthroscopic surgery" and they're better off cutting the larger chunk.
Other options are making access panels into your ceiling on the off chance that you haven't run enough wire or need to get at your joist area to run wiring.
Unless you have 7' at joist level, I'd go with a drop ceiling.  GO INVESTIGATE WHAT THE PANELS CAN LOOK LIKE!  Lots of times, people think drop ceilings ONLY come in that "been hit with buckshot" look and simply assume that's what they all look like.  You can get many different patterns - most folks just don't like to do much special ordering.
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #17 on: February 28, 2006, 09:45:40 pm »
I was in Salt Lake city and toured the the various buildings in Temple Square.
In the basement of one of the buildings, they had a drop celiling with "black" tiles, no windows.
You would thinks that it would be dark and grungy, but looked real sleek.
I'm thinking of going this route.
I agree with the others on ability to access everything with a drop ceiling.
In my last -1 houses ago, a pipe burst and I had a drop ceiling Othe than some wall damage, just popped out the offending tiles and put new ones in. Would have abeen a nightmare if drywall. Plus,
I hate mudding, I wonder how hard it would be to mud a ceiling....
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
ClubNinja
  • Last login:October 19, 2010, 12:46:02 pm
  • Comfortably Numb
« Reply #18 on: March 01, 2006, 09:58:54 am »
Only slightly more annoying that mudding a wall - which, relatively speaking, is really 'effing annoying.
« Reply #19 on: March 01, 2006, 09:59:57 am »
The more I hear about mudding the less I am looking forward to figuring out how to do it.
CCM
« Reply #20 on: March 01, 2006, 10:51:50 am »
If you've never done it before, it would be money well spent to have someone come in and do that for you.  Any imperfections in the finsihing will show and you will see them everytime you step into your basement.  I'm speaking from experience, the first mudding jib I did was a small bathroom in our house, and I still see every mistake I made.
dmsuchy
« Reply #21 on: March 01, 2006, 11:37:41 am »
Pay a mudder! They finish the job in half the time and make it look great. Mudding sucks period.
xar256
  • Last login:February 03, 2025, 08:50:13 pm
« Reply #22 on: March 01, 2006, 12:31:06 pm »
Actually, mudding is the easy part of the whole thing...It's the sanding that sucks monkey balls.   :P  It doesn't take too long to master so long as you don't cut corners, but lordy do I ever hate the sanding.
Xar256 ;D
whammoed
  • Last login:February 17, 2026, 12:42:21 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #23 on: March 01, 2006, 12:43:16 pm »
Xar256 ;D
Agreed.  Isn't that why they invented textured walls?  ;D
I'll, hang it, tape it, mud it....just don't make me sand it.
CCM
« Reply #24 on: March 01, 2006, 02:35:47 pm »
Xar256 ;D
Mudding and sanding go hand-in-hand,  if you scew up the mudding or put it on way too thick, it's gonna make the sanding that much harder.  For a first-timer getting the walls and corners smooth is very difficult.
fredster
  • It's all good!
« Reply #25 on: March 02, 2006, 12:45:05 pm »
There is plaster spraying.
Like they do with textured ceilings.  You can rent one of them at a tool rental place and just spray textured stucco.
You could even color the stucco and you would be done pretty quickly.  It would be pretty cheap and easy to do that.
DrewKaree
  • HAH! Nice one!
« Reply #26 on: March 02, 2006, 04:40:59 pm »
That's called "Knock-Down". It's just chunks of stuff (mebbe styrofoam?) that you throw in a hopper and usually you spray that on, let it set for however long it says in the directions, and then spray a coat or two of paint over it.  Problem comes in if you don't know what you're doing.  That stuff tends to come off easily if it's not done right.
« Reply #27 on: March 02, 2006, 04:44:35 pm »
Can't stand that stuff, anyway.  I don't like textured wall surfaces... bugs me for some reason.  We have textured swirls on our ceilings and I find them distracting.
fredster
  • It's all good!
« Reply #28 on: March 02, 2006, 05:03:27 pm »
So many patterns.  It's disturbing to you isn't it?
DrewKaree
  • HAH! Nice one!
« Reply #29 on: March 02, 2006, 05:06:31 pm »
It's like wunna dem Horseshack tests ta Chad!
« Reply #30 on: March 02, 2006, 08:58:09 pm »
It won't shut up.  It keeps telling me to do things.  I won't do them.  Make it stop.
BTW, the best way to finish a basement ceiling is with a roundhouse kick.  Chuck Norris cannot be wrong.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #31 on: March 03, 2006, 10:14:19 pm »
I don't see much need for drop ceiling, regardless of whether you put in all the wiring you could possibly ever need.  $10 of PVC pipe will give you all the wire chase you'll ever need.  Drop ceiling is certainly easy access, but I don't think access needs to be that easy to something you only need access to once every three or four years -- or never.  Personally, I'd be inclined to not even give myself any access to the wire chase and if I realized down the road that i needed to upgrade to Cat 7 I'd just punch a hole in the ceiling and run my wire.  It would take all of fifteen or twenty minutes to patch and paint the hole.
Best Kid iPad Apps
mccoy178
  • Go Bucks!
« Reply #32 on: March 03, 2006, 10:42:54 pm »
...I'd just punch a hole in the ceiling and run my wire.  It would take all of fifteen or twenty minutes to patch and paint the hole.
I think you are grossly misrepresenting the time and effort it would take to do that.  It's not child birth, but that doesn't mean it doesn't suck.  I thought you lived in an apartment?  I'm just asking, have you done work like this before?
DrewKaree
  • HAH! Nice one!
« Reply #33 on: March 04, 2006, 01:35:05 am »
You're forgetting the cost, time, and amount of repair needed if you have a plumbing problem.  With a drop ceiling, if a major problem happens, you'll generally have far less to repair, costs can and will mount with a drywall ceiling, and if you do it yourself, the time needed to redo drywall is way more than just popping out a few panels and replacing them.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #34 on: March 04, 2006, 10:16:13 am »
Jutting spikes at random angles.  Sharp ones.  Keep those darn kids from jumping on the bed.
mccoy178
  • Go Bucks!
« Reply #35 on: March 04, 2006, 11:18:35 am »
Hey!  I saw your kids lip.  Jumpy little buger eh?
shmokes
    • Jake Moses
« Reply #36 on: March 04, 2006, 01:45:16 pm »
I live in an apartment but I grew up in a house where we refinished our basement when I was about 15, and I've worked for my brother, who is a carpenter, a dozen or so times doing drywall work.
Your plumbing disaster scenario is specious.  Why not make all your bathroom walls out of tiles that can be pushed out of place too?  And why not use a concrete tunnel in your yard instead of, you know, dirt and lawn in case you need access to those pipes?
I don't for a second contest that the time it takes to punch a hole in the ceiling to access the wire run and then patch it back up will be far more than what it takes to pop up a drop ceiling tile.  But saving an extra hour or even three hours of work once every 3-10 years is not worth the time and expense and loss of ceiling height and poor aesthetic of installing a drop ceiling in the home.
Best Kid iPad Apps
DrewKaree
  • HAH! Nice one!
« Reply #37 on: March 04, 2006, 03:36:27 pm »
You're being idiotic on purpose.  The odds that you'll have a problem INSIDE the house are more likely, which is why your yard scenario is retarded, and you make cleanouts and access panels for your bathroom.
Since you PURPOSELY create access panels for things elsewhere in the house, why not make the ceiling a series of access panels?
There's more problems associated with drywall that JUST plumbing problems, that just happens to be the largest one.  Time spent up front for installing a drop ceiling would equal out if you needed to replace your drywall.  Money spent on drywall, tape, mud, paint, mudding knives, etc will add up to be quite comparable to installing a drop ceiling, especially if anything needs to be fixed on that drywall.  Loss of ceiling height.  Seriously?  2 friggen inches?  You make it sound like you're going to lose a foot if you install a drop ceiling.   Aesthetics?  They make TONS of different tiles, and if you want to go that route, you have many to choose from to suit your needs.
I never said drywall for a ceiling was a terrible way to go, but it seems like since you think they're "aesthetically challenged" (read: ugly), you're making it sound like putting in a drop ceiling makes a person an idiot for choosing that route, when clearly there's many pluses to it.
mccoy178
  • Go Bucks!
« Reply #38 on: March 04, 2006, 05:11:54 pm »
I feel the love in the air.
