Author Topic: Trimming T-Molding  (Read 3145 times)
Lon
  • Last login:March 31, 2006, 04:32:00 pm
Trimming T-Molding
« on: February 26, 2006, 12:57:55 pm »
Hi there, i have done a search and not found a method for trimming the overhang of the t-molding flush. I tried using a brand new single edge razorblade, but was not happy with the results, very uneven and the t-molding looked better untrimmed. Is there a method to get a consistant flush cut?
Thanks,
Lon
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
Re: Trimming T-Molding
« Reply #1 on: February 26, 2006, 10:19:24 pm »
I used scissors once and got a very uneven cut. I got better luck the next time with a sharp utility knife. Take your time and go for a perfect 90-degree cut. Don't rush it. You might want to do some practice runs first.
-pmc
Witchboard
  • Last login:January 05, 2022, 09:09:24 pm
    • Oklahoma Coin-Operated Collectors
« Reply #2 on: February 26, 2006, 10:26:42 pm »
Thanks,
Lon
Are you talking about trimming it in regards to overhang on the sides of the cab, or cutting it when you're finished installing it at the end?
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #3 on: February 26, 2006, 10:26:59 pm »
How about an edge trimmer for iron-on edging.
http://www.rockler.com/product.cfm?page=1266
If you build a frankenpanel, chances are I don't care for you as a person.
Excretious
  • Last login:February 02, 2022, 10:53:12 am
« Reply #4 on: February 26, 2006, 11:08:19 pm »
That looks handy, thanks for the link  ;D
wrench
  • Last login:August 02, 2024, 03:16:38 pm
  • Another project I couldn't say no to
« Reply #5 on: February 26, 2006, 11:17:13 pm »
I used that edge trimmer on my t-moulding and it worked great. Got mine here
http://www.specialtytools.com/cgi-bin/web_store/web_store.cgi?page=t_mold/tnet93.html&cart_id=7218427_11282
It had a couple of sharp corners that tended to scratch the t-moulding during trimming,but a fine file to the sharp edges and corners on the trimmer fixed that
jimmah
  • Last login:August 29, 2013, 10:52:32 am
« Reply #6 on: February 27, 2006, 05:39:41 am »
I just used a pair of scissors. I cut the part that bangs into the wood out first and then just cut the rest flush with the cabinet.
Lon
« Reply #7 on: February 27, 2006, 12:58:23 pm »
Thanks,
Lon
I am referring to the overhang. i want it flush. It looks like one of the edge trimmers might be what I need.
thanks,
Lon
