January 31, 2026, 04:41:32 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Main
Main Forum
Removing a Tron spinner knob
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Removing a Tron spinner knob (Read 2005 times)
spidermonkey
Trade Count:
0
Full Member
Offline
Last login:October 01, 2023, 04:15:59 am
Bombjack junkie
on:
February 17, 2003, 03:33:39 pm »
Any of you guys ever remove the knob off of a Tron spinner ? I have one but its so rusty I can't tell if its a set screw or a small roll pin. My guess would be a set screw but I tried a few sizes of allen wrenches but nothing grabs but again that might be due to rust clogging up the hex hole. I have a bad feeling I'm going to have to drill it out and re tap some new threads but first I just want to make sure that its not a roll pin.
Logged
"Sinistar has bad breath"
OSCAR
Trade Count:
0
Full Member
Offline
Last login:September 06, 2018, 11:31:53 pm
I think Bigfoot is blurry, that's the problem...
Re:Removing a Tron spinner knob
Reply #1 on:
February 17, 2003, 04:03:52 pm »
Mine, and others I've seen, use a roll pin. And every one I've seen has been rusty, too. If you can find a long enough punch or nail set, you could probably tap it out.
Logged
Karman
Trade Count:
0
Full Member
Offline
Last login:April 28, 2015, 10:11:46 am
Reply #2 on:
February 17, 2003, 05:27:44 pm »
Remove the two allen head set screws at the very bottom of the spinner that hold the main shaft. The knob and shaft will slide right out the top. Once you have the shaft and knob out, you can see and access the underside of the knob and the roll pin that holds it on. A pair of needle-nose pliers should get the roll pin out through the bottom of the knob.
Logged
2slk
Trade Count:
0
Full Member
Offline
Last login:February 27, 2004, 11:38:09 pm
Fascinating, Captain.
Reply #3 on:
February 17, 2003, 06:21:12 pm »
Just tried it on mine and it worked like a charm. Thanks Karman.
Logged
spidermonkey
Trade Count:
0
Full Member
Offline
Bombjack junkie
Reply #4 on:
February 17, 2003, 11:36:56 pm »
Ahh ok, Good thing I asked before I started drilling away. I have a much better chance of removing a rusty role pin rather then a corroded stripped out set screw.
Thanks all !
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
