Author Topic: CGA monitor/MAME/ArcadeVGA/Width shifting between resolutions  (Read 1505 times)
killbill
  • Last login:Today at 04:31:25 pm
  • When I die, I want to go to arcade heaven!
« on: February 21, 2006, 07:02:16 pm »
Hi Guys,
I'm old school when it comes to MAME, but a newbie with the MAME interface with arcade monitors.
I picked up a 25" CGA WG k7400 monitor.  I hooked it up to my ArcadeVGA 9200 chipset card, and used minwah's MAME resolution tool to set the appropriate game resolutions.
The result was great; BUT there is one really annoying issue.  Here's an example:  I set the width and height of the screen in accordance with Street Fighter 2. Looks great.  Then I run Golden Axe.  The screen shifts to the left leaving a nasty 1" black border on the right hand of the screen.
It seems this happens when I switch to certain resolutions.  Is there any way to correct this?  My width adjustment is maxxed out as it is, so i can't just make the screen wider.
Any help is truly appreciated.
« Last Edit: February 21, 2006, 07:03:55 pm by killbill »
DirkDiggler_ESQ
  • Last login:June 01, 2011, 10:26:09 pm
Re: CGA monitor/MAME/ArcadeVGA/Width shifting between resolutions
« Reply #1 on: February 22, 2006, 10:51:35 pm »
I've got similar issues with my U2000 (the k7400 replaced it).  I'll keep watching this post, but let me know if you get any private messages with a fix.
