Author Topic: need a new monitor. some questions.  (Read 1758 times)
drumlogix
  • Last login:April 25, 2006, 09:51:13 pm
  • MK-MAME Project.
« on: February 18, 2006, 07:40:40 pm »
Hello,
     I have been working on my very first MAME cab since the beggining of winter. I found a guy who has tons of arcade cabs for sale in my area and amazingly he had the exact cab I was looking for, Mortal kombat 2. MK2 has been my favorite arcade game. I pumped insane amount of money into these machines.  And because I did not have the proper tools to actually cut up wood and build a cab from scratch I went for this . He sold me the whole cab with all original components for 250$ all it was missing was the monitor. This is a original MK2 cab and not a mk1 or some other conversion. I had gotten a used (very) monitor from the same guy a few weeks later. It was a WG K7000 series manufactured in 1992. After using it for a month the thing crapped out on me. The image was completly distorted, Would make some very loud sounds too. So I took it to the guy for repairs and he did it for free, It worked for about a week then same thing started happening. I am now to the point where I would like the buy a new one. This time not used and no burn-in. Now my question is this. What monitor would be best for heavy mame use and mamewah. The now broken monitor I have is 25''. So I do not think a d9200 would work becuase they are 27''. What model should i get that will support highest resolutions. I see the k7500 supports slightly higher res than the k7000-k7400's. I am confused however becase the WG site says they do not have it available and HAPP says its made for certain games. Does this mean a k7500 25'' will not work with my mk2 cab? I am willing to spend good money on this and i really want to get the best possible resolution i can. Does anyone know IF a d9200 would fit in a orig mk2 cab? it looks like i have some space to spare and it might fit but would i need to move mounting brackets? Is there a monitor like the d9200 but that actually comes in 25''? Thanks for any input on this!
-Ty
Q*Bert_OP
  • Oh yes, we did!
Re: need a new monitor. some questions.
« Reply #1 on: February 18, 2006, 08:22:35 pm »
Unfortunately, only a low res. monitor will work for MK2 because it was only intended as a low res. game, I recomend a new WG K7401 24.8 in monitor.
drumlogix
  • MK-MAME Project.
« Reply #2 on: February 18, 2006, 11:28:50 pm »
what is up with this k7500? http://www.happcontrols.com/monitors/49028200.htm . is that not even available yet? or is it only for certain cabs? seems to go up to 640x400 rather than the others 640x200.
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
« Reply #3 on: February 20, 2006, 07:55:15 am »
Most arcade monitors only have one resolution. They are not like PC monitors where they can switch between diffrent resolutions.
