February 12, 2026, 06:16:08 pm
Looks like a primitive (yet effective) alarm system
Quote from: Level42 on February 17, 2006, 06:08:29 pmLooks like a primitive (yet effective) alarm system Yep, I don't think it's working anymore, but it looks like the airhorn would have gone off if someone tried to smash in or pull out the coin-door lock. Peale was saying that he's come accross a couple of them in the machines that he and his boss are selling.
Hey, would you be willing to scan that bezel for the arcade art library?
This particular machine used to be serviced by me. We acquired a ton of machines with that so called "primitive" alarm. IT WILL TEAR YOUR FACE OFF!!!! I started disabling them on the route w/ a couple of zip ties after accidentally setting a couple off. If the can of R12 is still full then it will work. I recommend setting it off outside for giggles = )
if that stuff in the air horn is really R12 - you could potentially sell it to a mechanic as it is pretty expensive stuff these days. Also bad for the ozone layer if released into the atmosphere.
I know, people get tired of hearing this... but that cab is SO restorable. Side art is only about $60, overlays are available, you'd just need a few random parts to make it look just like a Centipede again. Could still leave MAME in it.
Great CP JoyMonkey ! Could you give the dimensions of it ? I have an old beaten up Gravitar cab and the original CP on it has tons of holes. I 'd like to check if metal CP for those cabs are the same, so that I can consider having one made like you with your specs, if you don't mind.Thanks
I know, people get tired of hearing this... but that cab is SO restorable. Side art is only about $60, overlays are available, you'd just need a few random parts to make it look just like a Centipede again. Could still leave MAME in it.Wade
So...how is it going?
um, what the hell is this?
Quote from: Peale on July 14, 2006, 11:38:08 pmSo...how is it going?Funny you should mention it, I'm going to make another control panel for it today (this time without a trackball) and do a little work on that ---smurfy--- red paint tomorrow.Quote from: danny_galaga on July 15, 2006, 12:41:21 amum, what the hell is this?That's a high-tech anti-theft device. If you try to rip the coin-door out without properly unlocking it, it sounds the air horn.
