Author Topic: How can I tell if the I-pac 4 will work with my pc in Dos mode?  (Read 1794 times)
RickDIII
  • Last login:June 03, 2007, 10:18:28 pm
  • Finished 1st Cab!
« on: February 16, 2006, 10:12:35 am »
Ok,  I'm finally getting ready to kick my project into gear and finally got the $$ to get some of the things I want.  I was looking at the i-pac 4 for encoding.  I am running a PII 500.  I thought I would run it in straight up dos mode.  Do I need to actually run windows?
From the Ultimarc site about the ipac 4:
No special drivers needed. USB drivers are generic Windows. On many motherboards USB will work in DOS.
How can I test if USB will work with DOS on my machine?
Thanks for all feedback!
whammoed
  • Last login:Yesterday at 02:34:51 pm
  • Crack don't smoke itself
    • NiceMite
Re: How can I tell if the I-pac 4 will work with my pc in Dos mode?
« Reply #1 on: February 16, 2006, 10:21:08 am »
Do you have a regular usb keyboard?  If so plug it in and check it out.  Why not just use it with the ps2 port though?
RickDIII
  • Finished 1st Cab!
« Reply #2 on: February 16, 2006, 11:19:01 am »
I thought the ipac 4 had to be used with usb.  Did I miss where it says it can be used with PS2 port?  ???
Hoopz
  • Last login:January 24, 2026, 09:24:43 am
  • Intellivision Rocks!
« Reply #3 on: February 16, 2006, 11:27:23 am »
Yep, you probably missed it.  From Andy's website:
56-Input button/joystick switch interface. USB or PS/2.
Since you are using DOS, PS2 will probably be easier for you.   Good luck.  :D
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
« Reply #4 on: February 16, 2006, 11:33:36 am »
You can order it as either USB or PS2.  You confirm what one you want when you order.  If your using DOS then I would recommend PS2 version.  Even PS2 version if running 95/98/ME.  USB worked with these, but they all had some troubles.  2000 and XP should be OK USB version.
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
RickDIII
  • Finished 1st Cab!
« Reply #5 on: February 16, 2006, 12:47:14 pm »
ps2 it is!  Thanks all!   ;D
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #6 on: February 16, 2006, 06:32:22 pm »
My IPAC-4 has PS/2 output, with a ps/2 to usb adapter on the end of it.  Most modern motherboards support USB keyboards at the BIOS level also, so either option is a possibility.
To test it..
step 1: plug in IPAC
step 2: boot to DOS
step 3: mash buttons
RickDIII
  • Finished 1st Cab!
« Reply #7 on: February 16, 2006, 07:14:56 pm »
To test it..
step 2: boot to DOS
I don't have a usb keyboard and wanted to ask the question before I purchased the IPAC.  Just trying to avoid purchasing an item that wouldn't work.
But it helps knowing that the ps2 is native with a usb adapter.  Thanks for the feedback!
Tiger-Heli
    • Tiger-Heli
« Reply #8 on: February 17, 2006, 10:57:34 am »
Correction - AFAIK - if you order PS/2, you only get PS/2.  If you order USB, you get an extra cable that can be used as USB as well as the PS/2 cable.
Sounds like you just need the PS/2 version, but you might pay the $5 extra for the USB cable in case you upgrade down the line and don't have to order it again.
USB BIOS support does not mean that a USB keyboard will work well in DOS, AFAIK.
Silverwind
« Reply #9 on: February 17, 2006, 04:20:01 pm »
That is how mine came.  I figured since I'm already spending XX dollars for the IPAC might as well spend a few more for the usb adapter.  Works great for me either way.
