Author Topic: Help me install car amp in my cocktail cab!  (Read 2788 times)
rackoon
  • Last login:February 16, 2026, 06:26:24 pm
  • I EAT PENCILS!
« on: February 15, 2006, 01:35:15 pm »
Let me start by stating that I was an electrician 15 years ago in my early 20's. Yet most of this work is pulling wires though color coded holes in half built track homes; theres not a lot to figure out when all 600 houses are wired the same and every thing is color coded with chalk. Basically what I am saying is I understand some electrical theory yet small electronics are my weak point.
  Ever since I read in Saints book that some folks have used car amps to power their cab's audio system I knew that's the way I wanted to go. So in my early parts collecting stage of cab building I acquired two 90watt 6x9's, the Oscar recommended potamiter, all necessary wires, and a car 300watt equalizer/amplifier. This isn't anything more than I had in my old Chevy Nova and Matalica's Ride The Lightning always sounded good. No wonder I am freak'en half deaf.
  Let me add that I am building a three sided cocktail table and the speakers will be about shin high and I am half deaf from loud, front row, head banging, metal concerts in the 80's.
So I don't think this set up will be over kill, and, if it is, even better. IF ITS TOO LOUD THEN YOUR TOO OLD! What I! I cant hear you! Speak up!
So here is my problem, (besides being long winded) I need to power a 300watt 12v ( its going to suck up 25 Amps at the most) car amp in my cab. This means that I need to go from 110v AC to 12V DC and end up with at least 25 amps.
Options so far:
1.  Can I use a 600watt PC power source? Some of them list 28 amps going to the 12v line. (I am weary of this rout because if I add up all the amps one of these things put out on all of its lines together its around 100 amps) this cant be right.
2. Should I buy a converter to go from 110v to 12v, then a inverter to go from AC to DC, then install a resister so I don't smoke my amp.
3. Give up my hopes and dreams a of a killer, rocking, gnarly, ---smurfette---'en, totally boss cab and just fade into  meritocracy.
   I know one of you guys know how to do this. This forum is full of smart and electronically     savy people. Please help!
They treated me like an animal and that's what I became.
pcates
  • Last login:January 05, 2011, 08:15:57 pm
Re: Help me install car amp in my cocktail cab!
« Reply #1 on: February 15, 2006, 01:51:18 pm »
I have an amp running off a computer power supply from a pentium computer (you can switch it off from the power button). I think it might be better to run it from an old arcade power supply, but I have not had any problems yet.
Patrick
ShinAce
  • Last login:January 16, 2007, 07:38:14 pm
  • Building the unbuildable since 2001
« Reply #2 on: February 15, 2006, 02:00:34 pm »
You don't NEED 25 amps. Sound is logarithmic, so even if you have a 2.5 amp supply, it will be plenty loud.
I'd go with a pc power supply and call it a day.....
On the amp, short the remote terminal with the positive power terminal. Now just run your gnd wires and power wires from the supply to the amp.
An ounce of image is worth a pound of performance.
somunny
  • Is it hot in here?
« Reply #3 on: February 15, 2006, 02:08:21 pm »
I replied to your thread over in the audio section...
rackoon
  • I EAT PENCILS!
« Reply #4 on: February 15, 2006, 03:10:54 pm »
This is great. You guys are a big help. I totally appreciate this. Furthermore, I have now read the link to the MAMEWorld amp site and it was a big help.
Although I do have just one more small question.
First what is a remote terminal? Is it for the switch for the on/ off for when it is in a case?
Havok
« Reply #5 on: February 15, 2006, 03:58:04 pm »
The remote terminal senses voltage and then turns on the amp...
rackoon
  • I EAT PENCILS!
« Reply #6 on: February 15, 2006, 05:37:38 pm »
My amp doesn't have  a remote terminal. I think that is because it is a amp/equalizer and has a power switch on the front. Although, it does list two different ways of grounding the unit. One setup has the speaker grounds and amp ground connected and calls this a common ground and the other has them separate. I was going to hook it all up to the PC power source ground. Hope it doesn't make a difference. I only bring it up because the amp has a big red sticker on it that says grounding to car frame will destroy amp.
Thanks for all the help so far. I plan on buying a PC power source off eBay in the next couple of days and testing this all out. I also hope to get one that has enough amps on the 5v line to hook up the 100 UV LED's that I have.
