Author Topic: how do i print the templates at 100% scale?  (Read 1951 times)
bossyman15
  • Last login:March 05, 2012, 01:35:08 pm
  • I am now building my own arcade controls!
    • Bossyman15 Arcade Pics
« on: February 11, 2006, 12:22:28 am »
i tried printing templates from project arcade CD but all of them end up being full size of the paper not the right size.
how do i make it print at 100% scale?
i'm using paint (its the only program i have!)
My website: www.bossyman15.com Lots of arcade pictures inside!
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
Re: how do i print the templates at 100% scale?
« Reply #1 on: February 11, 2006, 01:32:23 am »
Install the 60 day trial version (fully functional) of Paintshop Pro ( on the CD ). This will allow you to print at 100% scale. I have no idea how to print at 100% in plain MS Paint.
My old user name was marlborroman13, but I kicked the habit many years ago!
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« Reply #2 on: February 11, 2006, 11:56:32 am »
Find the local print shop with large format printing equipment.  It will be the one that local architects and engineers use.  Take the image files to them.
I don't know how you would print templates for an arcade cabinet full scale at home with mspaint, unless you plan on doing a lot of scotch taping.
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« Reply #3 on: February 11, 2006, 12:39:24 pm »
It's a resolution setting. I figured it out a while back. I know that there's a thread concerning this in the BYOAC Book forum. I'll see if I can find it.
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
« Reply #4 on: February 11, 2006, 01:00:36 pm »
You can also use Adobe or something.  THe main setting you need to look for is a way to span multiple pages.  In adobe you go into the Print page and select TILE ALL PAGES and then set the paper size and it will print it out on multiple sheets you can tape together.
Other programs shoudl have the same functionality.
bossyman15
« Reply #5 on: February 11, 2006, 10:13:12 pm »
ok i installed that program but when i print it at 100% scale (i hope i did) the buttons didn't come out right size... the buttons are only about 3/4" wide not 1 1/8"
i tried everything i could in that program but it still comes out the same.
AMDman13
« Reply #6 on: February 11, 2006, 10:17:56 pm »
Did you try going into "grid guide & snap" properties and set them to grids = 1 inch? Also make sure that zoom is set at 100%?
I'm no pro at this by any means... But give it a try and let us know!
bossyman15
« Reply #7 on: February 11, 2006, 11:20:25 pm »
no it didn't work it's still the same
maybe something's wrong with template itself maybe its wrong size or something.
anybody have different template of 7 buttons? in jpg fomat?
AMDman13
« Reply #8 on: February 11, 2006, 11:30:30 pm »
Probably dumb question, but are you using the templates that are included with the "Project Arcade" chapt 6?
bossyman15
« Reply #9 on: February 12, 2006, 06:25:03 pm »
Yes I am. Why? Is that the problem?
