Author Topic: Change MameWAHs list scroll amount?  (Read 1041 times)
Farmboy90
  • Last login:June 26, 2006, 12:15:04 am
  • My cab is done... Pics coming soon!!
« on: February 09, 2006, 10:45:37 am »
Is it possible to change how many games mamewah will scroll the list when you move left or right (like page up page down).
I would like to tailor it so that it moves exactly one screen away instead of what it does now.  This way it will function in a page up/page down fashion.
SlyDog
  • Last login:September 08, 2006, 11:21:16 pm
Re: Change MameWAHs list scroll amount?
« Reply #1 on: February 09, 2006, 11:26:01 am »
If you use the mamewah config with 1.6 you can change it to do page down instead of going to next letter like the default
In the config go to Global settings tab-then click the controller button (you may have to "install" a controller i just put pad)-this should say "edit controller"-on the global tab check the box that suits you (i use all three mouse kb and joystick)-then click the controller tab and you can set the settings on pg down pg up one item down one item up etc.
Hope this helps I was never good at explaining things if you need more info i will try to do a screen shot walk through
Woof
