Author Topic: Nintendo 64 Best 6 button configuration set up  (Read 3925 times)
killbill
  • Last login:December 17, 2025, 04:32:58 pm
  • When I die, I want to go to arcade heaven!
« on: February 08, 2006, 03:02:13 pm »
HI,
I'm running Project64 on my cab.  I have a six button Street Fighter set up.
For any experienced Nintendo 64 people out there, in order to be able to play the most games without a control problem, what would be the best six button config for the 64 on a cab?
What I mean is: should the "A" botton be mapped to button 1; etc.
Thanks.
killbill
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re: Nintendo 64 Best 6 button configuration set up
« Reply #1 on: February 08, 2006, 03:26:32 pm »
dont do it man.. spend the extra loot and get some adaptoids and genuine n64 controllers.
Flinkly
  • Last login:March 14, 2017, 01:14:21 pm
« Reply #2 on: February 08, 2006, 03:32:45 pm »
yeah, it's the same thing as having genuine arcade controls, cept i wouldn't fork out 50 dollars for an adaptoid.  buy a generic adapter, they work just as well for controllability.
on a side note, how are the compatibility numbers with project 64 so far?  when i tried it about this time last year, too many of the games just weren't properly emulated yet.
« Last Edit: February 08, 2006, 03:34:47 pm by Flinkly »
SlyDog
  • Last login:September 08, 2006, 11:21:16 pm
« Reply #3 on: February 08, 2006, 03:38:33 pm »
This is hard to say.   Just depends on what N64 games you plan on playing.  i am using a ps2 controller in my pc and each different game i play i have to remap the buttons.   zelda uses all the c buttons so you have to map them kinda next to each other... mario kart uses Cdown so it should be close to A so you can fire while driving.. etc.  Basically like screaming said just hook up a N64 controller and make it like the demo tv at walmart or something.
Not only that the controller has 10 buttons (including start) plust the dpad then the analog so the 6 buttons may not be enough for the right game
Fat_Trucker
  • Last login:September 08, 2010, 11:44:22 am
« Reply #4 on: February 08, 2006, 03:45:38 pm »
I'm using a Playstation 2 controller usb adapter on my cab for console games.
It costs
« Last Edit: February 08, 2006, 03:53:19 pm by Fat_Trucker »
I didn't touch it....honest!
screaming
  • Registered lUser
« Reply #5 on: February 08, 2006, 03:58:33 pm »
  I thoght they had issues with specific controllers (generally non-Nintendo ones), with using two at once, aren't rumble-pack compatible, and can't use N64 memory cards?  The adaptiod ones work all around.
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
« Reply #6 on: February 08, 2006, 06:20:53 pm »
I say spend the extra money and find an Adaptoid. The are supported natively and have full functionality. They work great.
John
Sensei
  • Last login:May 03, 2008, 11:30:58 am
  • Take this pebble from my hand.
« Reply #7 on: February 09, 2006, 12:29:15 am »
John
I second that.  When I first put Project64 into my cab I thought I could use all the same buttons and joysticks that are on the cab.
It sucked!
So a nice little wireless MadCatz controller stuffed away inside the cab when not in use was the way to go.  It was effortless to configure inside Project64.
Besides what would you do if you dont have an analogue stick on your cab to use for N64 games.  There is no easy way to play a lot of games without analogue.
Good Luck to you.
  • Last login:Today at 01:32:52 pm
« Reply #8 on: February 09, 2006, 06:34:28 am »
Well considering the n64 controller has NINE buttons and an ANALOG STICK  I think you might have to use the original controllers.
Sorry to yell, but ask a stupid question.......
screaming
  • Registered lUser
« Reply #9 on: February 09, 2006, 09:40:12 am »
  Not all games use all buttons though, which i think was some of his subtext.
  I still think anyone who wants to run N64 games on their PC needs an adaptoid with original controllers.  Save up your allowance and splurg.  You wont regret it.
