Author Topic: Mala - Can you run different games from different Mames?  (Read 6576 times)
More Cowbell
  • That's just dumb!
« on: February 06, 2006, 12:23:08 pm »
My system isn't super fast (1.1Ghz w/ 750megs ram) so I have a new Mame to run most of my games and an older Mame (.66) to run some games that stutter in the new Mame (games like NBA Jams TE). Is there a way to configure Mala to runs some games out of Mame1.03 and some out of Mame.66?
I've got a fever...
loadman
    • MaLa
Re: Mala - Can you run different games from different Mames?
« Reply #1 on: February 07, 2006, 02:32:18 am »
Yep..Sure can
Even though I'm sure it was not designed to work that way.  :-*
Enter the mame version you use least as a 'other emulator'
I just tried it using MaLa version 1.0 Beta and worked great
http://mala.arcadezentrum.com/Beta2_11.09.exe
You may want to put the roms you want to use with it in a different directory so that the list looks about right straight away
« Last Edit: February 07, 2006, 04:21:01 am by loadman »
More Cowbell
  • That's just dumb!
« Reply #2 on: February 07, 2006, 09:12:05 am »
Thanks, Loadman.
I was just pondering on it last night and came up with the same concept. Glad to know it works. Now all I need to do is sort out 2,000 games to determine which ones work best with which Mame version. Mmmmmm..... project.......
I've got a fever...
loadman
    • MaLa
« Reply #3 on: February 07, 2006, 06:03:43 pm »
Or you could rob a gas station and buy a decent pc  ...Well not really  :D
