Author Topic: Document only: New listxml format and Listgen  (Read 1178 times)
BuZz880
  • Last login:November 16, 2023, 02:16:43 pm
« on: February 05, 2006, 08:22:50 pm »
I thought I would document this in case anyone else cares.
It looks like Budda's Listgen has been broken since 102.  It is due to changes in the listxml format.
I do not know if anyone else uses this tool (or other tools that are messed up by this minor change) but if you do, all you need to do is find and replace on the new listxml.txt the following:
find:
 build="0.103u5 (Feb  3 2006)">
replace with:
EDIT:  Budda's listgen for some time has required you to generate listxml.txt yourself outside of the program, that issue is well documented in this forum somewhere.  All I am showing here is that you now have an additional step since 102 that needs to occur also outside the program.
« Last Edit: February 05, 2006, 10:25:30 pm by BuZz880 »
Buddabing
Re: Document only: New listxml format and Listgen
« Reply #1 on: February 05, 2006, 11:32:05 pm »
find:
replace with:
Thanks for the heads up, I'll fix it asap.
Please read the wiki!
