Author Topic: How do I wire a Miniature Momentary Contact Pushbutton?  (Read 1677 times)
« on: February 03, 2006, 04:08:06 pm »
I have a bunch of "A" buttons from Happs for admin functions.  http://www.happcontrols.com/pushbuttons/49057700.htm
THANKS!
unclet
Re: How do I wire a Miniature Momentary Contact Pushbutton?
« Reply #1 on: February 03, 2006, 04:29:00 pm »
one pin is wired to ground, the other pin is wired to your encoder.
I do not think it matters which pin you connect ground to ... just pick one.
« Reply #2 on: February 03, 2006, 04:59:36 pm »
That's it?  Sounds easy enough to me.  THANKS!
unclet
« Reply #3 on: February 03, 2006, 05:01:36 pm »
I got a couple of those buttons from Radio Shack and that is how I wored them up .... they work fine.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: February 03, 2006, 05:05:53 pm »
Yep, a switch is just like touching two wires together, doesn't matter which pin does what, as long as it completes the circuit.
