Author Topic: Help me with my setup!  (Read 1418 times)
effdubya
  • Last login:January 01, 2007, 09:03:49 pm
« on: February 02, 2006, 06:42:54 am »
I have a p4 2.8 running with an x800 pro
im planning on hooking this up to a television which has a scart input
i have read up on the various vga->scart writeups, and searched the forum, the problem is i've got too much mixed info.
is a circuit required or does it simply involve joining wires together?
does the circuit prevent damage from occuring to the tv input/pc output?
cheers!
-fw
Harry Potter
  • Smite-bait
  • Last login:May 27, 2024, 03:33:28 am
  • Sober until banned. Can post but still can't read.
Re: Help me with my setup!
« Reply #1 on: February 02, 2006, 11:09:04 am »
You can't go directly from the vga port to scart unless you have an ArcadeVGA (or unless you want to see some cool whirly patterns on your TV  ;D ).
Well actually you can but you will have to make friends with AdvanceMAME. Also you'll need a video card which can be tweaked to 15khz using AdvanceMAME.
« Last Edit: February 02, 2006, 11:13:44 am by Harry Potter »
Now in a tasty new flavour.
