Author Topic: MiniPac & Happ TB  (Read 1038 times)
ojelela
  • Last login:May 16, 2007, 09:59:37 pm
MiniPac & Happ TB
« on: January 30, 2006, 06:56:10 pm »
Hi
I'm getting pretty close finishing my cab. My setup is PIII 700 with win 98 se
and Mamewah.Got my magstiks plus and minipac from Andy.Everything seems to be working fine but TB  not so good.
            I'm using win98 se and when is booting up gives me Keyboard Error but it goes on. When win 98 comes up keyboard seems to be working ok, but in Device Men. it shows 3 keyboards, one Standard and two HID-compliant keyboards. I tried to uninstall one HID but it comes back. For mouse it shows two, one standard and one HID. There is no conflict with any of them.My orig. mouse works fine in windows but TB when you move it all it does is shakes up or down and no left or right movement at all. On CD that came with board I didn't see any drivers and I don't know if I need any?? I tried to swap X1 Y1 and X2 Y2 but there is no difference. I'm really running out the ideas what to do, or what I'm doing wrong.
      When I run Winipac this what I get?!
I email Andy and he suggested to check wiring, but it seems to be ok.
I'm sorry to bug you but Your help at this point would be appreciated.
ojelela
Re: MiniPac & Happ TB
« Reply #1 on: January 30, 2006, 08:11:23 pm »
Newer mind :P, I got it.
It was "simple" ground thing didn't realize that matters which ground, gnd1
to X axes and gnd2 to Y axes. I had only one ground connected.
That solved one problem, and also noticed Andy has X and Y mixed up on his web page for happ TB.Only now don't know why I get "Keyboard Error" on bot up it doesn't do any harm its just annoying beeping on power up and It pause for 4 seconds.Also my CP setup has 2 joy 6 PB each 1 & 2 player button and I will have coin door working for coin 1 & 2. I really don't have to much room so I tried to keep CP as simple as possible.
Now is it possible to have working like that with no ESCAPE key and MOUSE 1 &2 since I can't
start Winipac???
Any idea how to solve that???
« Last Edit: January 30, 2006, 08:24:29 pm by ojelela »
