December 04, 2025, 07:18:56 am
Don't know about any body elses, but I did mine. It was easy. http://homepage.mac.com/mahuti/defendercade/PhotoAlbum45.htmlI decased and mounted a TV in mine using the old arcade monitor brackets (they fit TVs just fine... better than they do computer monitors. The only trick was finding a way to easily mount the tv's circuit board. I ended up cutting off the TV casing mounts screwing them to the metal and simply zip-tieing the circuit board to the plastic mounts. I also desoldered, moved and rewired the IR signal up into the marquee so I could still easily use the remote... without the IR being visible. I've also decased and mounted a TV to a wood 2x4 frame when I didn't have a metal monitor bracket handy. That's just as easy.
