Author Topic: Missing wire in jamma harness, how to replace ?  (Read 913 times)
markymarky99
  • Last login:August 20, 2017, 01:53:05 pm
« on: January 29, 2006, 11:01:15 pm »
Hi, I have an arcade cabinet already wired up JAMMA, however, I need number 15 on the harness to hookup an interlock switch so that I can negotiate the multi board menu system.  The entire wire and pin is missing, there's just a hole there.  I've purchased pin after pin but can't seem to find what I need to insert into this hole and run a new wire.  I don't want to wire directly to the jamma board as this is a 500 dollar unit.  Not worth ruining.  What is another way of getting this stubborn number 15 pin to work for me ?  any ideas ?  The hole in the harness seems to be bigger than the standard jamma harness of today, this is an old cabinet.
Ken Layton
  • Guru
  • Technician
Re: Missing wire in jamma harness, how to replace ?
« Reply #1 on: January 30, 2006, 01:37:08 am »
If your Jamma harness connector is the black one then Bob Roberts sells the correct pins to insert.
If your Jamma harness connector is the tiny blue one you're screwed.
