Author Topic: phpBB - We've all seen it, we're all using it, but how do I play around with it?  (Read 995 times)
Crazy Cooter
  • Senator Cooter was heard today telling the entire congressional body to STFU...
  • Last login:August 19, 2025, 11:29:13 pm
So I "installed" in locally.  Now how do I edit the templates?  Do I seriously have to code this stuff by hand if I want my own look?  What about a *ahem* simple color change?  I'm used to WYSIWYG & phpbb.com is a little overwhelming  ::).
Can someone nudge me in the right direction?
lcddream
  • Last login:December 04, 2024, 03:59:31 pm
  • Say goodbye to gravity...
you need to read the readme i think...there is an admin page you can goto, like a control panel.
Crazy Cooter
Notepad messes up the formating of the template code.  Front Page 98 doesn't though.  I can open the cfg and tpl files and see it as formatted text.  It makes a bit more sense that way.
Now can I have a "window" open so I can change some colors/images in the subsilver style image folder and view what graphic it is?  Or am I going about this the wrong way?
Stingray
I used PHPBB on my old forum. There are very few features and the admin interface seriously sucks. When I moved the forum to the new host I switched to SMF software, the same software that this forum uses. It's much, much better. Try it out and see if you agree with me.
-S
Crazy Cooter
WHOA...  :o
SMF is much simpler.  Is it easiest to just upload it to a temp directory and start playing with it "live" on the server, or should I try to get it running "semi-live" locally?
Goz
  • KOTA
Much easier to just upload to your host in a temp dir and play.
