February 27, 2026, 09:19:27 am
you use the new caommand line options in mame that remove them... it's in the mame documentation and you can also set it in the mame.ini
Quote from: Howard_Casto on February 11, 2003, 12:04:20 pmyou use the new caommand line options in mame that remove them... it's in the mame documentation and you can also set it in the mame.inithat's hardly an answer... at least give 'em a link or something HC =PWhat you need to do is
Thanks everyone.BTW I am currently running Mame .62 so I would not be able to find the answer in the Mame readme. I appreciate those of you who took the time to give me a complete answer. I now know that I need to update to v.64 or v.65 to get this functionality. Thanks again to all,Marco
Quote from: rampy on February 11, 2003, 01:56:18 pmQuote from: Howard_Casto on February 11, 2003, 12:04:20 pmyou use the new caommand line options in mame that remove them... it's in the mame documentation and you can also set it in the mame.inithat's hardly an answer... at least give 'em a link or something HC =PWhat you need to do is
Quote from: marcopolo on February 11, 2003, 11:13:44 pmThanks everyone.BTW I am currently running Mame .62 so I would not be able to find the answer in the Mame readme. I appreciate those of you who took the time to give me a complete answer. I now know that I need to update to v.64 or v.65 to get this functionality. Thanks again to all,MarcoThere is no option to get rid of the "OK to continue" screen as far as I know. Its a warning screen to let you know the game does not play 100%. The other two nag screen options are in the 'Interface options" in Mame32. To get thru the OK screen without a keyboard all you need to do is press LEFT then RIGHT on your controller or use the arrows on the keyboard.
