Author Topic: Do happs supers and x arcade sticks have the same base plate ?  (Read 3462 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
Hi does any one know if the happ supers ave the same base plate as x arcade sticks ?
 I want to get a set but i don't want to have to drill different holes for the bolts and end up with a cp overlay full of holes.
SNAAKE
  • Trade Count: (+29)
Re: Do happs supers and x arcade sticks have the same base plate ?
« Reply #1 on: January 26, 2006, 03:52:37 am »
Yes same
Yoder
  • Last login:November 22, 2006, 04:35:24 pm
« Reply #2 on: January 26, 2006, 01:54:19 pm »
Yes, although they're the same design with the leaf microswitches....so you may not feel much of a difference.  Many on here don't speak highly of X-arcade sticks so it may still be a nice upgrade.  I haven't tested my x-arcade against a super, though.  I switched to a competition...haven't really put it thru it's paces, yet.
Let us now how they feel if you do the swap.
HOTR6
  • Last login:November 13, 2006, 09:21:13 am
« Reply #3 on: January 26, 2006, 03:30:32 pm »
Did your Competition sticks line up? Are there certain sticks that DON'T line up? I am thinking of replacing my X arcade sticks but want to make sure I don't have to re-drill
Necro
  • Last login:December 31, 2025, 03:36:17 pm
  • Building a 'Classic' MAME Cab
« Reply #4 on: January 27, 2006, 10:11:27 am »
I'm interested in this as well, if I ever end up replacing my joysticks in the future...(I kind of like the 'pull up and switch from 4way to 8 way' ones over at Ultimarc.
pointdablame
« Reply #5 on: January 27, 2006, 10:33:27 am »
Xarcade and Supers use microswitches, not leafswitches.  And the XGaming microswitches are worlds different than a good Cherry switch IMHO, so I definitely notice the difference.
The Xarcade and Super have the same bolt pattern, I've switched some before.  I also believe the Comps have the same as the super, so they should fit as well, I just can't remember if I ever personally swapped in a Comp to one.  The Supers definitely work though.
first off your and idiot
SNAAKE
« Reply #6 on: January 27, 2006, 10:52:24 am »
super,ultimate,xarcade,comps,p360 have same bolt pattern.
