Author Topic: Is grounding a must?  (Read 1424 times)
truthfacer
  • Last login:July 20, 2006, 04:34:49 am
« on: January 24, 2006, 11:51:37 am »
Hey Guys!
Do I HAVE to ground all my buttons on a controller connected to a pc through an interface??
And how do I ground 'em??
--->I want to wire a Neo-Geo-Joyboard to the x-arcade-interface. the case is plastic only ... so grounding? ....yes I am a non-technichian :)
Thanx Robert
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
Re: Is grounding a must?
« Reply #1 on: January 24, 2006, 12:45:46 pm »
Yeah, in order for the input to be triggered, it needs to be grounded. You can ground two ways. The first being you daisy chain the grounds of each microswitch together, just link them and send them all to a common ground on your encoder. You could also use a terminal block, you'd just take all the grounds to the terminal block and run a wire to the ground on the encoder. Most people chose to do the first.
I had to beat them to death with their own shoes...
truthfacer
« Reply #2 on: January 24, 2006, 01:29:09 pm »
Ok. I know the grounds for my buttons. How do I find out which is the ground for the knob? there are two connections to each direction.
Farmboy90
  • Last login:June 26, 2006, 12:15:04 am
  • My cab is done... Pics coming soon!!
« Reply #3 on: January 24, 2006, 01:35:11 pm »
The ground is the same as for the buttons.  It is the "top" tab on the microswitch.  The one labeled common.
thebrownshow
  • Last login:December 14, 2010, 03:14:32 pm
« Reply #4 on: January 24, 2006, 02:04:44 pm »
Wait, grounding for the knob?  Are you confusing the "Ground" for the actual connection for the switch with something else?  Are you talking about actually grounding the plastic BUTTON?
truthfacer
« Reply #5 on: January 24, 2006, 02:37:21 pm »
Yeah that was a good one!
truthfacer
I'm done with it!
« Reply #6 on: January 25, 2006, 02:34:46 pm »
Alright I connected the neo-geo-joyboard to my x-arcade-single. If anyone cares about that newbie-loser mod. No probs......except: I have the worst tools ever! Hate nothing more than bad tolls. word
Thanx for the help.
Robert
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #7 on: January 25, 2006, 06:19:38 pm »
When you refer to "the knob", are you talking about the joystick
If not, unless Ashton70 is on your CP, we'll need more info ;)
