Author Topic: Ultimarc Ipac Programming issue  (Read 3667 times)
  • Last login:Yesterday at 11:47:10 pm
« on: January 23, 2006, 01:35:01 pm »
being a "computer person" I expected the building of the cab to be the hard part and the computer stuff to be the easy part! Perhaps someone can tell me what I'm doing wrong -
I have the ipac wired up to a 2 joystick with 2 buttons each, I also have a quarter (5) and player 1 (1) button and a quarter (6) and player 2 button. All those buttons work fine. I have a dedicated Pause and Quit button but I cannot program them to be P and Esc.
I opened the ipac config utility. Create a blank board and assign all the keys to the board and save my config. Then I click the program utility and it says it's programming the ipac, but when I open notepad the changes didn't take.
I wired the Escape and Pause button to player 1/2 button 8.
Any help will be greatly appreciated.
loadman
    • MaLa
Re: Ultimarc Ipac Programming issue
« Reply #1 on: January 23, 2006, 07:54:55 pm »
I would use this rather than the GUI's (Overkill in my opinion)
http://www.ultimarc.com/interact.html
It's simple and effective
Good Luck
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
« Reply #2 on: January 23, 2006, 09:37:49 pm »
In the settings option, did you set your IPAc to the right model and connection?  If this has a jumper on it, is it set to ALT, not MAME?
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #3 on: January 23, 2006, 09:54:54 pm »
That's my first guess too. You have to switch the jumper to ALT to be able to modify the programming.
If it's not that... well, we have a starting point to work from.
If you build a frankenpanel, chances are I don't care for you as a person.
« Reply #4 on: January 24, 2006, 08:50:47 am »
I see jumpers on the board, but there currently isn't anything jumped - it's all exposed pins.
What I did to fix the problem was open notepad and hit cntrl+alt+p to program it. I never could get the ipac program to work.
Thanks for the help. I knew the answer was on the board somewhere. The search on the forum kind of sucks, I ended up going to google typing in search terms that connected me to the BYOAC forums.
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #5 on: January 24, 2006, 02:10:07 pm »
How so? I search these boards constantly with little trouble. There is some down time sometimes, and the other day it was giving error messages, but it's a good search when it's working.
