Author Topic: Got me a CAB "pic's inside"  (Read 3180 times)
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« on: January 23, 2006, 01:06:11 am »
Hey guys
New to the forum, Picked me up a mk2 cab at a auction in (toronto) it looks like it was converted to play SF alpha 3, the monitor works but the game doesn't, someone hacked the CP cause the MK2 has the 5 button setup other holes were drilled to accomadate the 6 button SF layout, messy drilling is causing the buttons to loose, so i decided perfect mame cab, picked up a I-pac cause i'm making my own CP, so here's my question
1, i have a wells Gardner (25k7197) 25" monitor (25khz and 53khz refresh) how do i rig this up to my pc, i heard arcadevga, anyone have Diagrams,
2,im confused as to how im going to run the power in the cab, the switch at the top would power my monitor and marquee, while i would have the PC power up on its own
Heres some pics
http://i35.photobucket.com/albums/d180/turbodubz/100_1501.jpg
http://i35.photobucket.com/albums/d180/turbodubz/100_1500.jpg
http://i35.photobucket.com/albums/d180/turbodubz/100_1499.jpg
http://i35.photobucket.com/albums/d180/turbodubz/100_1498.jpg
http://i35.photobucket.com/albums/d180/turbodubz/100_1497.jpg
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
Mr-Megalo
  • Last login:July 13, 2006, 08:36:28 am
  • Piano fingered Capcom Addict
Re: Got me a CAB "pic's inside"
« Reply #1 on: January 23, 2006, 05:10:11 am »
off topic, how do you know the SFA3 game isn't working ?
if the cabinet is a medium res monitor, I can understand why it wouldn't display a picture as SFA3 is a low res 15k JAMMA game although it would make no sense fo it to have a 15k JAMMA game installed in a medium res environment - but it should still at least power the CPS2 board, if the fans kick in on the CPS2 but you get no sound from the game then I would hazzard a guess that the CPS2 has commited Capcom Suicide (the internal battery has died), if however you can hear it say "this is Street Fighter Alpha 3" then i'd be confident the game works okay. Even if the board has committed suicide, you can still have the eeproms re-programmed by Razoola from CPS2Shock
will the SFA3 and marquee be for sale at any point ? SFA3 blue boards aren't as common as the Japanese green ones. it would be worthit to someone to get the board pheonixed
MAME TIME
« Reply #2 on: January 23, 2006, 10:46:10 am »
Hey Mr-megalo
When i saw the game at the auction it said monitor working game not, when i booted up the cab it came up with a red screen then a black, no sound , if your intrested i know of a distributor that could check the board,
Geometry Arcade
Neo Geo 360
MK2 standup
Mr-Megalo
« Reply #3 on: January 23, 2006, 09:02:21 pm »
I actually allready have SFA3 - both a blue version and an All In One Black version, but i do think it would be worthwhile to someone who would be interested in fixing it via CPS2 Pheonix fix.
it might be worth eBaying it - the marquee aswell
are you sure the monitor is a medium res one ?
MAME TIME
« Reply #4 on: January 24, 2006, 09:56:20 am »
i figured since it was in a mk2 cab that it was a med res monitor, not too sure if they did the complete swap, ill check it out
Geometry Arcade
Neo Geo 360
MK2 standup
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« Reply #5 on: January 24, 2006, 10:04:24 am »
Hey guys
Heres some pics
Welcome to the forums all your answers can be found using the search button.
Curls in the squat rack !?!?!
Harpal
  • Last login:April 02, 2006, 12:02:22 pm
  • I'VE STARTED BUILDING MY FIRST MINI ARCADE!!!
    • 3D-ARCADE at MAMEWORLD
« Reply #6 on: January 27, 2006, 07:38:24 pm »
cab looks in good condition, good buy
so was it a bargain then??? ;)
HAPPY NEW YEAR!!!!!
---------2006-----------
Timstuff
  • Last login:April 16, 2014, 02:24:29 am
  • I feel asleep !!
« Reply #7 on: January 30, 2006, 04:07:04 pm »
That cab looks like it's in good shape aside from the "Frankenstien" job they did turning it into SFA3. If I were you, I'd give a shot at restoring it's exterior to how it would have looked in it's MK2 days, since all you seem to need is a repro Marquee and CPO (and you'll likely have to cut a new control panel, since you said the drill job they did was messy). So yeah, I'd try to do an MK2 Mame Machine. 8)
MAME TIME
« Reply #8 on: February 01, 2006, 12:14:54 am »
thats the exact plan i have in mind, my mk2 marquee should be on my doorstep in a day or so and i just started my new control panel, its going to stay with the mk2 theme, should look good, im going to get the alpha board tested and sell it along with the marquee and the 2 instruction cards
Geometry Arcade
Neo Geo 360
MK2 standup
