Author Topic: Can't believe myself..  (Read 2793 times)
ojelela
  • Last login:May 16, 2007, 09:59:37 pm
« on: January 22, 2006, 10:33:55 pm »
I finally got mamewah running on my comp. and I was trying to boot straight into it.
I found post where someone said:
About 10 posts down.
Just realized your on Win 98, that makes it even easier. In your system.ini file I believe, change the line that reads "SHELL=explorer.exe" to your mamewah  executable. That'll do the trick
I did that on my win 98 and now it said "Can't load mamewah.exe.....Please Reinstall Windows"
It won't even let me go to safe mode.Please does someone know how to go back to Explorer.exe????? :'(
JoyMonkey
  • Voodoo Wiki Master . . .
    • JoyMonkey.com
Re: Can't believe myself..
« Reply #1 on: January 22, 2006, 10:44:31 pm »
Boot your computer with a Windows 98 Bootdisk, then edit your system.ini back to it's original (shell=explorer.exe).
ojelela
« Reply #2 on: January 22, 2006, 10:51:10 pm »
Thanks, I did boot it up  but have no clue how to edit system.ini now from here.....
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: January 22, 2006, 10:58:18 pm »
type "edit"
NO MORE!!
ojelela
« Reply #4 on: January 22, 2006, 11:08:38 pm »
Ok did that too, got blue screen I can type but like I said no clue how to edit or what to type.... ???
ojelela
« Reply #5 on: January 22, 2006, 11:24:53 pm »
Got it, Restarted and the F8, then Command Prompt only, and then edit system.ini from there.
Thanks God. Now does anybody knows why it happened because it all works no problem if I start it........
Minwah
    • MAMEWAH
« Reply #6 on: January 23, 2006, 06:32:50 am »
Did you give the full Mamewah path (eg 'shell=c:\mamewah\mamewah.exe')?
ojelela
« Reply #7 on: January 23, 2006, 08:32:44 pm »
No, I didn't because Explorer didn't have full path so I "figured" ::) it would be ok.You think that was the problem??
Bingo...That did it...Thanks Minwah
« Last Edit: January 23, 2006, 10:31:16 pm by ojelela »
ojelela
« Reply #8 on: January 23, 2006, 08:40:19 pm »
Just I thought I had it.......Only thing now when I quit MameWah there is no Windows (Explorer) to go back to it. Is there any way around this problem now or is it ether or Mamewah or Explorer ???
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
« Reply #9 on: January 23, 2006, 09:06:41 pm »
There is an option in MameWAH to run an app one exit. Set it to explorer.exe.
John
ojelela
« Reply #10 on: January 23, 2006, 10:08:25 pm »
Thanks John, will try....
jcrouse
    • CPViewer
« Reply #11 on: January 23, 2006, 10:27:59 pm »
Make sure you set the ESC key to "Exit and Run App" or something like that in the mamewah.cfg file (if your using the latest beta).
John
Flinkly
  • Last login:March 14, 2017, 01:14:21 pm
« Reply #12 on: January 24, 2006, 05:03:48 pm »
what about just powering down?  i have my power button set in windows to power down, but if i shell...?
