Author Topic: Which row to connect RGYB on chassis, does it matter?  (Read 1245 times)
markymarky99
  • Last login:August 20, 2017, 01:53:05 pm
« on: January 20, 2006, 04:03:16 am »
HI, just received a discount monitor from Ebay.  Of course, no directions.  I know where the wires from the tube go onto the chassis except for the RED, GREEN, YELLOW,BLUE hookup.  There are 2 rows of four poles on the chassis, how do I know which row to insert the plug in to, and, does it matter ?  Why is there 2 rows?  Also, once I have the right row, what is the order of insertion ?  If I put it on wrong, is the picture just going to not look right or will there be any damage?  Thanks for your time!
Ps, I have no idea what type of monitor it is, as usual, just a generic old picture tube with a new chassis of some sort.
markymarky99
Re: Which row to connect RGYB on chassis, does it matter?
« Reply #1 on: January 20, 2006, 04:05:53 am »
hi, forgot to include the pic of what I'm looking at on the chassis...  which way to inset the RGYB cable?  thanks!
grantspain
« Reply #2 on: January 20, 2006, 12:17:28 pm »
Thats your scan coil plug,you cant plug that in wrong because the pins are offset-the only thing you will get is possilbly an upside down picture,but then you just plug into the other connector.
