Author Topic: what did YOU do with that green ground wire on your happs t-ball?  (Read 1586 times)
s8n
  • Last login:April 02, 2003, 06:12:12 pm
  • The Prince of Darkness
just wondering what im supposed to do with it. ???
Tehrasha
  • Last login:January 17, 2004, 04:21:43 pm
  • Spammers suck!
    • Darkon2002
Re:what did YOU do with that green ground wire on your happs t-ball?
« Reply #1 on: February 10, 2003, 01:46:35 am »
I put it under one of the star-nuts that holds the metal plate which is also wired to the common ground of the entire cabinet.
The box said 'Use Windows 95 or better' so I installed Linux.
CCM
« Reply #2 on: February 10, 2003, 11:54:23 am »
I didn't do anything with it.... it's just hanging loose in my CP box.  I've had it like that for a few months with no problems.
wee beastie
  • Last login:October 06, 2003, 03:33:02 pm
« Reply #3 on: February 10, 2003, 02:51:16 pm »
The ground wire is there for a reason.  If I were you, I'd connect it to the ground on your power supply.  Or to the PS metal housing as that should be grounded
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #4 on: February 10, 2003, 03:00:36 pm »
I attached it to the +12v on my computer's power supply. Kinda smells like incense...........
KIDDING!  ;) DON'T do it!
If you build a frankenpanel, chances are I don't care for you as a person.
CM
  • Last login:January 02, 2012, 08:59:17 pm
  • The internet?!? Is that thing still around?
« Reply #5 on: February 10, 2003, 04:59:20 pm »
I thought it went to 110  :o
Just kidding as well!  Don't do that either
Seriously,  its been awhile since I hooked mine up, but I think its there to ground out static that can build up on the ball.   I play Marble-Madness on dry days with fuzzy-slippers after playing with my Van DeGraaf generator .. so I grounded mine.  :)
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #6 on: February 10, 2003, 05:09:15 pm »
that's funny as hell... thanks =)  maybe run a de-humidifier with that as well to make sure it's extra-dry... maybe drink some gin while you are at it too)
rampy
