Author Topic: well gardner u3100  (Read 1892 times)
squire
  • Last login:May 06, 2014, 12:31:17 pm
well gardner u3100
« on: January 19, 2006, 06:34:08 pm »
i was planning to get the wells and gardner u3100 19 inch
for my cab due to the vga adapter.
but i was searching around and i noticed it was giving people
promblems.
and it said the max res was 1024 x 768 but was hard to achive this.
is this true?
is the any good vga compatible moniters beside this line that any body could recomend?
i wanted to use the arcade style moniter for the fell and so i could use the exsting moniter mounters for it.
thank for you for any input in advance!
JONTHEBOMB
  • Last login:March 28, 2025, 11:39:04 pm
  • BOOM!!!!
Re: well gardner u3100
« Reply #1 on: January 19, 2006, 08:30:02 pm »
Hello squire,
I'm also planning to using a U3100 for my cabinet.  I wondering if you remember what thread said the max resolution 1024 x 768 is hard to reach.
whammoed
  • Last login:November 25, 2025, 03:34:11 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #2 on: January 19, 2006, 08:40:15 pm »
Hello squire,
will only do 1024*768 interlaced...and looks pretty bad.
Its really only a 31Khz monitor, so you won't even be able to run 800*600 at a 60hz refresh.
why not think about the billab 19" autosync?
http://www.billabs.com/bl19c91k_u.htm
at least its also capable of the old school cga resolutions and ega too.
squire
« Reply #3 on: January 19, 2006, 08:49:28 pm »
Hello squire,
thanks for the input
does this moniter have a vga hookup?i did not see it listed.
i really apperciate the help im glad i did not waste money on regret..
whammoed
    • NiceMite
« Reply #4 on: January 19, 2006, 10:37:27 pm »
Yes, it has a vga input.
I don't think the u3100 would be a waste, but it looks like there may be better alternatives now.
squire
« Reply #5 on: January 20, 2006, 11:17:01 am »
thaks again..
i was reading in the forum that this model is discontinued?
is this true.
or was it the 25"
and is it jus plug and play?
i dont know to much about these moniters,but been learning more and more just looking around here.
i just talked to kristin about this moniter at billabs.
and she really didnt know to much about but she was helpful from what she did understand.
she said the max res was 800x600
thank once agian
« Last Edit: January 20, 2006, 11:28:16 am by squire »
squire
« Reply #6 on: January 20, 2006, 04:51:27 pm »
ok i have the spec sheet on this moniter it is now called the
BL19CA1Q http://www.billabs.com/images/monitor_27_specs.pdf
but it wil not be in stock until med feb..
and the price is 349$
im stoked about this moniter sound like it will do the job right.
and there also taking preorders..
