Author Topic: SNES problems  (Read 1349 times)
Harry Potter
  • Smite-bait
  • Last login:May 27, 2024, 03:33:28 am
  • Sober until banned. Can post but still can't read.
SNES problems
« on: January 14, 2006, 05:51:51 am »
OK, not really a problem with the SNES but it is related to it.
I plugged it into my video projector today (Infocus X2), picture came up fine but the image was jumping up and down a bit. On a TV it looks fine.
Then I tried a Megadrive, which did pretty much the same thing except worse. TV looks fine.
I figured out that the problem is that the output video is non-interlaced.
Question: Is there some (simple) device out there that can re-interlace or double the fields in the video?
Otherwise I'll just get a Composite to VGA converter.
HP
Just on a side note, I noticed both the SNES and megadrive have RGB output capabilities. I'm assuming this is 15khz. Anyone confirm this?
« Last Edit: January 14, 2006, 10:30:56 am by Harry Potter »
Now in a tasty new flavour.
Harry Potter
  • Smite-bait
Re: SNES problems
« Reply #1 on: January 15, 2006, 05:23:27 am »
Never mind. Problem solved with composite to VGA converter.
