February 04, 2026, 04:49:07 pm
Game with standard resolution is ult. mk3, want to play nfl blitz, anybody know if this will work as i have a standard resolution monitor to test, thanks
Quote from: kjoel0123 on January 13, 2006, 11:21:35 pmGame with standard resolution is ult. mk3, want to play nfl blitz, anybody know if this will work as i have a standard resolution monitor to test, thanksOutside of board-level dip switches, some standard res monitors will downclock to accept 24-25KHz signals, although it depends entirely on the monitor itself. If you have one of those monitors that simply switches itself off when the input is out of range, you can test for yourself. Don't try it on monitors that don't switch off. While you probably wouldn't do any permanent damage, I really don't recommend taking the risk just in case.
You're saying a standard resolution monitor can run at a higher scan rate? I never heard of that. I could see it the other way around, a medium resolution monitor being able to accept standard resolutions but not a standard resolution monitor being able to accept 24-25 kHz.
