Author Topic: Another Bezel Question  (Read 1854 times)
MikeQ
« on: January 12, 2006, 01:21:44 pm »
Does anyone have a 27" FLAT monitor bezel from Happs?
I'm looking for the outer width and height (The overall width and height).
I've searched the forums but not found any dimensions for the flat, just the curved.
Thanks,
Mike
Roughy
  • Last login:July 01, 2009, 09:33:20 pm
  • Easily impressed.
    • UserGlue
Re: Another Bezel Question
« Reply #1 on: January 12, 2006, 01:49:38 pm »
Call 'em. I had to do that to get the measurements.
They'll give you the outside and inside (the opening) measurements.
I have a UAII cab and someone recommended the 19" monitor bezel--it ended up being 25" x 25" and I used my plexi scorer to trim it a little closer to size.  Then grinded it down a little smoother and then life is good.
Just try to find enough stuff from Happs to get your order over $25 or they'll charge you a $10 handling fee for the large--but inexpensive--item, which also sucks.
farmecologist
  • Last login:September 28, 2021, 06:41:53 pm
  • I'm not a llama!
« Reply #2 on: January 12, 2006, 01:51:16 pm »
I have one but I don't have it handy right now.
MikeQ
« Reply #3 on: January 12, 2006, 02:18:53 pm »
I emailed them a few days ago and they came back with measurements that didn't sound right.
I don't have them handy but the outside width was around 25" and the inside width was aroun 21".
MikeQ
« Reply #4 on: January 12, 2006, 02:20:22 pm »
farmecologist
  • I'm not a llama!
« Reply #5 on: January 13, 2006, 06:08:37 pm »
Sure, I can do that.
