Author Topic: The X-fact0r :: 1st project attempt  (Read 3835 times)
X-fact0r
  • Last login:July 21, 2019, 03:04:59 pm
  • Cabinet build in progress!
« on: January 11, 2006, 06:37:55 am »
Hi folks,
this is my first post so bare with me ;)
I have been lurking around for some time but only now I've found the motivation and conditions to embrace a cabinet project.
I am currently moving to another house and as a result the progress will be (very) slowly...
A couple of months ago I started to gather some info and best practices from several people that are building/built their cabinets and specialized sites such as BYOAC.
I have bought a used empty cabinet which I intend to recover and the basic concept is already laid out:
                           ** Build thread | Art thread **
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
Re: The X-fact0r :: 1st project attempt
« Reply #1 on: January 11, 2006, 08:57:15 am »
1 week with Illustrator? You did good kid.
Not sure of the font used, but once you find it, it would look great having all the artwork in the same font as well as the CP.
Good luck, looks like a good start.
BobbyG66
Half of the people you meet are below average.
Harpal
  • Last login:April 02, 2006, 12:02:22 pm
  • I'VE STARTED BUILDING MY FIRST MINI ARCADE!!!
    • 3D-ARCADE at MAMEWORLD
« Reply #2 on: January 11, 2006, 09:57:50 am »
once you have all the artwork done it all would look great.....
good work
keep it up :)
HAPPY NEW YEAR!!!!!
---------2006-----------
c64rulez
  • Last login:July 09, 2011, 05:08:36 pm
  • It's live and kicking
« Reply #3 on: January 11, 2006, 10:02:24 am »
That's a great combination of the atom mame logo and pacman.
Reminds me of Buggs Bunny ...
And thanks god they're not brains  ;D
markrvp
  • NFL Expert
« Reply #4 on: January 11, 2006, 11:11:03 am »
If you are using a TV, then you won't need the AVGA.  That is for when you are using a CGA monitor or a multisync monitor like the Wells Gardner D9200 or Betson Multisync.
Pixelhugger
  • Last login:October 14, 2025, 10:53:10 am
« Reply #5 on: January 11, 2006, 04:18:24 pm »
Handel Gothic is the name of the font. It's also floating around online under the name Niamey. I'm sure I have a free variant of it somewhere.
Project mega thread HERE
X-fact0r
« Reply #6 on: January 12, 2006, 04:57:34 am »
Quote from: BobbyG66
Did I forgot to mention that I work more or less regularly with PS? :P
Quote from: markrvp
X-fact0r
« Reply #7 on: January 16, 2006, 05:28:16 am »
I've updated the concept a little bit based on your previous input.
Any comments? ;)
Thanks.
Marquee
Sideart
ZeroPoint
  • Last login:June 19, 2014, 08:07:07 pm
« Reply #8 on: January 16, 2006, 07:25:40 am »
Nice Marquee, much better than the previous.
The transparent Mame logo on your sideart is a little disturbing.
My original idea would be using a TV through scart/euroconnector. I have read somewhere that you would get an almost perfect image quality and resolutions with this combination... now I'm confused
There is no problem using a TV for your arcade cabinet. As you say you wish to use a scart-tv. That is an excellent choice if you want to use real arcade resolutions.
A few advices/warnings for you when selecting/using a scart tv:
You have to adjust the overscan on your TV. This is done in a special service menu that is not useraccesible and can be hard to find.
On some new TVs the horizontal size is fixed in the hardware and cannot be adjusted even in the service menu. You actually have to replace parts inside the TV (a coil) to change the horizontal size. NOT recommended. (Please do not open your TV because I
dennis808
  • Last login:May 13, 2021, 08:40:00 am
  • Holy Sanwa-sticks!
« Reply #9 on: January 16, 2006, 09:28:20 am »
ZeroPoint is right that you're best off with a SCART-TV, both in picture quality as in costs.
But if you're scared when people start talking about vertical position, vertical liniarity, horizontal position and rgb horizontal position... ;)
This might be an easy alternative:
It's a scanline-converter that supports RGB-SCART:
http://www.trust.com/products/product.aspx?artnr=12737
You can get them on ebay (europe) for about
"Complexity is the process by which the obvious is obscured by the irrelevant." -HSW
c64rulez
« Reply #10 on: January 17, 2006, 02:28:15 am »
I've tested my tv (21" scart) with a plain AGP vga card and I got very satisfying results.
I'm using an S-video cable with a very simple tiny scart converter (cost 3$).
Can't post pictures right now, but I will when I can.
I did a lot of research regarding the tv connectivity, and although I did not try an arcadeVGA adapter I have no problems with the results.
I'm just tweaking the connection so that the tv goes right into AV mode. If I'm not mistaken (I can't verify it right now) it's 12v to pin 8. I'll check and repost
Have fun with your project.
dennis808
« Reply #11 on: January 17, 2006, 04:00:13 am »
Keep in mind that there is a difference between using the S-Video input on a SCART-type connector like this:
and converting the vga signal to an RGB signal wich also gets transported to the SCART socket, albeit on other pins.
c64rulez
« Reply #12 on: January 17, 2006, 06:54:41 am »
That is exactly the converter I have
radnads
  • Last login:October 07, 2019, 06:22:45 pm
« Reply #13 on: January 17, 2006, 02:06:17 pm »
I have a 27" tv connected via s-video to a geforce 4 s-video out and looks perfect.
The difference was made when a smoked tempered glass was set in front.  It sharpend the resolution beyond what s-vid to composite or scart can do.
Just to add
ZeroPoint
« Reply #14 on: January 17, 2006, 06:02:39 pm »
You could use s-video connection if you are happy with it, but you cannot in your wildest dreams compare it to a real rgb signal, and you for sure can
c64rulez
« Reply #15 on: January 18, 2006, 09:53:14 am »
