Author Topic: Need a reason to run cat5e to the....  (Read 1349 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« on: January 07, 2006, 05:07:17 pm »
Im in the crawl space and need a reason to justify running cat5e to the kitchen.. sounds like a good idea but for what..........
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
Re: Need a reason to run cat5e to the....
« Reply #1 on: January 07, 2006, 05:19:49 pm »
If you have the spare wire, theres this thing called the future.
I just moved into a new house, and being 15 I helped the elctrician wire about 80% of the house, and did about 45% of it solo.  One thing he told me is that since we bought reels of the wiring, use it!  We ended up using cat 5e wire for the PHONE lines, thats how much we had left.  Plus, I ran an extra 3 of them from my room to the central panel, and Ive found uses for them, so never second-guess something like that... USE IT ANYWAYS.
On the other hand, if you dont have the wire and youll ahve to cut your walls and crap to get it up there, dont bother.  They invented something called wireless now :)
Ed_McCarron
« Reply #2 on: January 07, 2006, 05:22:46 pm »
I'm just amazed that you have net access in your crawlspace.  Drag a laptop in with you? ;)
I just saw a net-enabled fridge at sears.
SithMaster
« Reply #3 on: January 07, 2006, 06:09:10 pm »
because youd be the first on your block to have a lan in your kitchen.
« Reply #4 on: January 07, 2006, 09:43:12 pm »
So you're ready when you decide to get a net capable fridge or Tivo in the kitchen.
Stingray
« Reply #5 on: January 09, 2006, 12:45:52 pm »
Porn in the same location where you store your beer. What was the question again?
-S
Goz
  • KOTA
« Reply #6 on: January 09, 2006, 01:13:06 pm »
Could easily stream video anywhere it goes...
TMS
  • Last login:September 21, 2006, 11:49:53 am
  • My cat loves comcast
« Reply #7 on: January 09, 2006, 03:18:19 pm »
Well if you plan to implement home automation in the near future cat5e/6 will be essential
http://www.control4.com/gallery/index.htm
