Author Topic: Mortal Kombat II colors  (Read 1116 times)
mmonte4
  • Last login:March 17, 2006, 09:43:06 pm
« on: January 04, 2006, 10:58:45 am »
hi, my MKII dedicated cabinet just arrived.  After a through cleaning its now up and running.  I have a question though.  How do I adjust the brightness level? I want to darken it, it seems too bright.  I went through the diagnostic tests but i couldnt find out how.
grantspain
Re: Mortal Kombat II colors
« Reply #1 on: January 04, 2006, 12:40:02 pm »
depending on your type of monitor there will be either an adjustment board or some pots on the chassis to adjust,they are usually clearly marked(use a torch),if you have flyback lines turn down your screen volts on the lopti.There is one other thing that can cause a poor picture and thats a low 5volts on the power supply,remember depending on your experience you have to be very careful with your hands in the back of a live monitor,i have been working in the amusement industry for 20 years and i still get the odd belt,good luck.
