Author Topic: IPac2 Function Removal  (Read 1248 times)
chris2922
  • Last login:March 26, 2023, 01:09:41 pm
  • Silverline Jamma Cab
« on: December 30, 2005, 08:27:02 am »
I am trying to remove a couple of the shifted functions bound to keys using my Ipac2.
I am using the Dos Ipac Utility.
How do i remove a function?
Every time i click an exisiting function to remove, all i can do is change it to another key.
The instructions dont mention how to do this and nor does the website.  Can anyone help please?
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
Re: IPac2 Function Removal
« Reply #1 on: December 30, 2005, 09:41:18 am »
Try either the "Scroll Lock" key or the "Pause/Break" key.
John
chris2922
« Reply #2 on: December 30, 2005, 12:21:44 pm »
Neither work, nor do they map themselves to the function - they dont do anything.
Thanks for trying...
Has anyone got any ideas please?  Im going nuts here!!!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: December 30, 2005, 01:40:03 pm »
chris2922
« Reply #4 on: December 30, 2005, 03:58:31 pm »
Using the "Ctrl-Alt-P" envoked program did the trick.  It allows functions to be removed completely.  It seems the DOS Ipacutil does not.
Thanks for your help.
loadman
    • MaLa
« Reply #5 on: December 30, 2005, 05:05:01 pm »
Using the "Ctrl-Alt-P" invoked program did the trick
That is all I ever use now.
The gui's are overkill for the simple job of allocating keys and functions in my opinion
chris2922
« Reply #6 on: December 31, 2005, 06:59:51 am »
Having used the Ctrl-Alp-P function for a few minutes i realised its much simpler to use than the gui.  I agree, and ill be using it from now on.
Also, what an ingenious solution.
