Author Topic: (newb) how can i................. CPO, artwork, buttons  (Read 2822 times)
muffin man
  • Last login:February 04, 2017, 03:08:21 am
« on: December 30, 2005, 04:31:52 am »
ok guys basically im tryin to make a custom control panel. and what i wanted to do was make a artwork with button placed on it to precise hole diameter for buttons and joysticks. problem with my control panel it is 47 inches by 19.5 inches triangle sides sort of like this
« Last Edit: December 30, 2005, 04:38:54 am by mus »
Do you know the muffin man......
Bones
  • [Moderator]
Re: (newb) how can i................. CPO, artwork, buttons
« Reply #1 on: December 30, 2005, 04:44:55 am »
I am struggling to understand your question. Are you asking how you line up the button/joystick holes between your artwork and your woodwork? If this is the case I used a template as seen HERE
If it is a software design question, many use Adobe Photoshop or Illustrator.
xonix_digital
  • Last login:February 20, 2016, 04:36:05 pm
  • I am the Milky-Way Commander!!!
« Reply #2 on: January 08, 2006, 07:36:41 pm »
Measure it out, draw it out, measure it out, and then measure it out again.
Then after all of this you can take your CPO design (that is to scale) and your CP design (that is also to scale) from whatever program you designed it in, and import both images into Photoshop on different layers.
The rest should be pretty self explanitory... if you have any photoshop experience.
-=XD=-
