Author Topic: Spinner wackiness  (Read 1150 times)
ChaosJohn
  • Last login:December 30, 2005, 06:04:34 pm
Spinner wackiness
« on: December 28, 2005, 07:02:10 pm »
I'm running the latest MAME32 on a Windows 2000 machine.  I have both
a trackball and a spinner working with it, but they're both pretty flaky.
Examples:
If I play Marble Madness, usually when I start it up, before I roll the
trackball at all, the marble rolls off the back of the maze.  If I roll as
fast as I can in the other direction, I can just keep it on the maze, but
not move it around.  Sometimes if I fiddle with setup stuff for awhile
it will work for a game or two, but it always comes back, even if I
don't change the settings
If I play Arkanoid, it forces the paddle all the way over to the right
and I can just barely drag it away from the edge.
Also, what's the difference between "digital speed" and "sensitivity"?
John
brophog
  • Last login:January 20, 2019, 03:49:41 am
Re: Spinner wackiness
« Reply #1 on: December 28, 2005, 07:03:28 pm »
Digital has to do with digital controls......i.e a joystick or keyboard. Sensitivity controls analog controls such as a trackball, mouse, or spinner.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: December 30, 2005, 05:25:43 pm »
Sounds like you have an analog joystick plugged in and joysticks enabled.  Disable joysticks for these games.  Also, you should calibrate your joysticks (or throw them out if they're gameport; gameports can uncalibrate quickly).
Robin
Knowledge is Power
