Author Topic: What to use to paint plexiglass?  (Read 983 times)
RTSDaddy2
  • Last login:April 03, 2014, 08:28:03 pm
  • Bees! Oh bother!
« on: December 28, 2005, 07:00:25 pm »
We're about to start the marquee...what sort of paint should we use to do our design so that the light will shine through it?
I did a search on here, but didn't turn up much.
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
Re: What to use to paint plexiglass?
« Reply #1 on: December 28, 2005, 08:45:54 pm »
You're better off NOT to paint plexi. You'll always end up with splotchy, uneven results. Original marquees were screenprinted. The more modern equivalent is to get someone to print out the full-sized artwork and put that behind a plexiglas sheet.
Many people use mamemarquees.com and emdkay.com to do this, or just find a local printer that can do oversize color prints such as Kinko's. If you go the Kinko's route, the Polypropylene is the cheapest and probably acceptable for what you need it for, but the backlit material looks better when lit.
rdagger
« Reply #2 on: December 28, 2005, 09:05:20 pm »
You can always paint plexi on the inside.  Then put the unpainted side facing outwards.
