December 30, 2025, 09:50:33 am
Results from resistance test on transistors:BDX53C: (+) collector to (-) emmiter: 4.55 kΩ (+) base to (-) collector: 1.745 kΩ (+) base to (-) emmiter: 7.3 kΩNTE2300: (+) collector to (-) emmiter: 0.5 Ω (+) base to (-) collector: 305.9 Ω (+) base to (-) emmiter: 306.4 ΩFrom these results, is it correct in stating that I would only need to replace the NTE2300 transistor? Thanks for the help.
I didn't have any diodes to perform a gain test. I was under the impression that a resistance test a valid way to test a transistor.
