Author Topic: Jakks and Computer monitor  (Read 2551 times)
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
« on: December 27, 2005, 06:41:35 pm »
I've searched (without much luck), to see if I could find any information on hooking up one of these Jakks Pacman / Ms. Pacman up to a old PC monitor.  Anyone do this?  If so, how did you do it?
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Jakks and Computer monitor
« Reply #1 on: December 27, 2005, 07:39:03 pm »
I don't think composite to multisync is possible. Not without an expensive convertor.
NO MORE!!
fredster
  • Grand Prophet of Arcadeology
  • Last login:February 16, 2019, 04:28:53 pm
  • It's all good!
« Reply #2 on: December 27, 2005, 07:45:30 pm »
Yeah, one is RGB and the other is NTSC. Not compatable.
You'd have to find a NTSC to RGB converter. They make them, and I think there are schematics for them too.
King of the Flying Monkeys from the Dark Side
MaximRecoil
« Reply #3 on: December 27, 2005, 08:47:54 pm »
You could do it through a PC into a monitor if you had a video card with composite input, like any capture card has (ATI All-In-Wonder is a common one). That would probably defeat the purpose though, because if you are going to have a PC hooked up you might as well use MAME or whatever.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #4 on: December 28, 2005, 12:05:58 am »
It's easy:
  • First, clean the old PC monitor up.
  • Sell the old PC monitor.
  • Buy an old used TV with the money you got from the monitor.
  • Hook the Jakk's unit up to the TV.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #5 on: December 28, 2005, 12:17:19 am »
Kremmit's got the least expensive solution, unless Windex or 409 is like $20 a gallon in your area ;D  The things to build end up costing about the same as the converters you can purchase, which run about $100.  I thought this same thing when first getting mine, and searched far and wide for that solution.  It is a no-dice situation.
eccs19
  • Just plugin away!
« Reply #6 on: December 28, 2005, 08:30:36 am »
Well thanks all.
« Last Edit: December 28, 2005, 08:32:13 am by eccs19 »
Project(s) - Pacman
fredster
  • It's all good!
« Reply #7 on: December 28, 2005, 11:04:57 am »
Your last hope is to search RGVAC and see if somebody has come up with a solution to this.
I did sometime back and there is a way to do this using a monitor, but it requires some hacking.
BTW, used monitors are worthless now.  You can hope to get $20 if it's nice.
eccs19
  • Just plugin away!
« Reply #8 on: December 28, 2005, 04:02:48 pm »
Project(s) - Pacman
DrewKaree
  • HAH! Nice one!
« Reply #9 on: December 28, 2005, 07:41:53 pm »
Wal-Mart had a nice little $60 tv (Durabrand?) that had all the requirements to be able to be used to hack this into a bartop if you were so inclined.  Less than the $100 converters :-\
Crowley
  • Last login:January 25, 2006, 04:07:23 am
  • Wakka-wakka-wakka-wakka
« Reply #10 on: December 29, 2005, 06:10:26 am »
*fanfare*
Yay for Lik-Sang!
http://www.lik-sang.com/info.php?category=219&products_id=3166&
$50, but it's worth it if you ask me.
"It's Raining Sideways!"
Kremmit
  • - AHOTW -
« Reply #11 on: December 29, 2005, 11:40:56 pm »
Interesting.  I didn't know those things were getting so cheap.
I see they've also got this one:
http://www.lik-sang.com/info.php?category=219&products_id=3235
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
« Reply #12 on: December 30, 2005, 01:00:51 pm »
The first one looks better because it has component input.
