Author Topic: Bondo and casters  (Read 1077 times)
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
Bondo and casters
« on: December 23, 2005, 12:19:38 am »
So I went and got an arcade cabinet for not too bad of a price.
Luckydevil
  • Last login:August 02, 2007, 01:38:45 pm
  • mmmm.... kilowatts.
    • Garage Junkies
Re: Bondo and casters
« Reply #1 on: December 23, 2005, 06:16:33 pm »
I have a CPS2 cab. The corners and the plywood bottom are both too weak for casters. This thing is HEAVY.
First I flipped the cab onto it's back with some help. Then what I did was cut 2"x4"s and screw/glue them onto the bottom one at a time. Be sure to screw them from the sides also for added support. I think I ended up using about 3 each for the front and back and then mounted the casters to the boards. it has held up fine that way.
For the first piece on each side I actually put the screws in from the inside of the cab and then put the screws in from the bottom for the rest.
Hope that helps.
Luckydevil
    • Garage Junkies
« Reply #2 on: December 24, 2005, 12:35:05 am »
Here's a pic of what I am yapping about...
