Author Topic: I have a question for all those PC guru's out there?  (Read 1304 times)
redcoats
  • Last login:March 15, 2015, 04:04:56 pm
« on: December 21, 2005, 04:25:20 pm »
I bought a used older PC on ebay some months ago and the PC came with Xandros 3.0.1 OC. Now this PC didn't come with any software whatsoever. I tried to do a reformat of it and now Im stuck.
I put a Win98 emergency boot disk in it to get FDisk to come up to reformat and everything seemed to format correctly but I wasn't able to use my Win98 CD because it is a set manufactures disk so it can only be used on one of my other PC's.
I figured that wouldn't be a problem so I went ahead and tried to install WinXP. I made sure I had the boot sequence correct in the CMOS, well it won't use the CDRom to boot even though I changed the sequence. So I went online and got the
« Last Edit: December 21, 2005, 05:58:18 pm by redcoats »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
redcoats
Re: I have a question for all those PC guru's out there?
« Reply #2 on: December 21, 2005, 08:13:40 pm »
Try this
http://support.microsoft.com/kb/q69013/
Wow thank you! I'll give this a whirl and see what happens.
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« Reply #3 on: December 22, 2005, 12:28:56 pm »
If you only have a Dell Windows CD, you can (legally) download a "vanilla" image of the Windows CD and install from that, using the same CD key (found on the COA) that you were originally using.
