Author Topic: Trailer hitch on a Civic  (Read 6241 times)
« on: December 14, 2005, 11:09:04 am »
Good idea?  Bad idea?
I have a lot of light duty stuff that I do and I'm sick of worrying about renting a pickup.  I can't replace a car any time soon nor buy an old pickup, so I'm thinking if I can rent a utility trailer when necessary that's cheaper and easier than a renting a truck...
Any thoughts?  I got a quote of around $160 to install, including cost of the hitch.
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
Re: Trailer hitch on a Civic
« Reply #1 on: December 14, 2005, 11:13:43 am »
sure it's allright if your going to be hauling mopeds around
« Reply #2 on: December 14, 2005, 11:14:34 am »
Heaviest duty I could think of would be a couple pins or cabs, the occasional couch... I have a huge pile of asphalt I need to move but I could do that in multiple trips.
whammoed
  • Last login:Yesterday at 02:40:57 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #3 on: December 14, 2005, 11:16:08 am »
Do they list any kind of tow rating in the manual or anyplace else?
Ed_McCarron
« Reply #4 on: December 14, 2005, 11:25:21 am »
Its probably so small, I bet they recommend not towing a trailer at all with it.
Whats the GVWR?  I can't imagine it being very large, and once you add the tongue weight of the trailer and a few passengers you are probably over the limit.
« Reply #5 on: December 14, 2005, 11:32:46 am »
Erf, can't seem to find it online... will have to keep looking.
Stingray
« Reply #6 on: December 14, 2005, 11:43:53 am »
You're talking about hauling, what, maybe 500 lb at the very max? You should be fine.
-S
Havok
« Reply #7 on: December 14, 2005, 11:48:18 am »
The GVWR should be on the car door - there's usually a sticker...
Ed_McCarron
« Reply #8 on: December 14, 2005, 11:49:16 am »
Plus the weight of the trailer.
My 4x8 trailer weighs over 1000 lbs unloaded.
When I let someone else load the trailer once, they put 3 heavy coolers of food/ice at the back, while the rest was fairly evenly loaded - causing a negative tongue weight.  Almost killed myself until I pulled over and redistributed the load.  Thing was whipping around like a live wire.
I can just imagine the same effect in a car thats 1/2-1/3 the weight of my Explorer.
Not saying it can't be done, just saying be -real- careful with trailers and loading.  Its very easy for the trailer to get out of control.
nostrebor
  • SHOCKING!!
« Reply #9 on: December 14, 2005, 12:09:18 pm »
-S
What he said.
 Just try to come up with a light trailer, and drive slow. The Harbor Freight trailers are not bad, cheap, and pretty light. I owned one for a while to pull an ATV... worked just fine.
<sarcasm>They are a lot of fun to put together too</sarcasm>
« Reply #10 on: December 14, 2005, 12:27:12 pm »
Since I don't have a place to store a trailer, I'd probably be renting one from Uhaul when I needed it.  I don't need it that often, either.
Anyone know how much an average cab actually weighs?  Use a bigger one, say a Dynamo.
Ed_McCarron
« Reply #11 on: December 14, 2005, 12:46:02 pm »
My Gauntlet machine claims to weigh 350 lbs, but me and another small guy managed to get it up a flight of stairs unassisted, so I think thats over the actual weight.
Stingray
« Reply #12 on: December 14, 2005, 12:48:09 pm »
I'd say a Dynamo is 300 or less. I can move mine in and out of the house myself, and I'm I'm harldly a big muscular beefcake.
-S
« Reply #13 on: December 14, 2005, 12:56:46 pm »
Moving something using a decent handtruck isn't much of an indicator of how much it will weigh on a trailer, though.
ErikRuud
« Reply #14 on: December 14, 2005, 01:13:56 pm »
I'm not sure which Civic you have but this site indicates that it is not rated for towing.
I think my 1988 Prelude was rated for 1000 pounds.
American Laser Games Wrapper
O2em Rom Utility
« Reply #15 on: December 14, 2005, 01:17:49 pm »
I should have noted it's a 4 door 1999 DX.
Stingray
« Reply #16 on: December 14, 2005, 01:36:56 pm »
I don't own a hand truck.
-S
« Reply #17 on: December 14, 2005, 01:37:39 pm »
Could you describe how you did it, then?  Corner swings?
Stingray
« Reply #18 on: December 14, 2005, 01:40:18 pm »
Back the truck up to the front door. Drop the tailgate, open the door, drag.
-S
Witchboard
  • Last login:January 05, 2022, 09:09:24 pm
    • Oklahoma Coin-Operated Collectors
« Reply #19 on: December 14, 2005, 01:42:28 pm »
Could you put that in Layman's terms?  ;)
« Reply #20 on: December 14, 2005, 01:44:21 pm »
Step 3:  pick up all the MDF crumblies from the floor.
Stingray
« Reply #21 on: December 14, 2005, 01:44:38 pm »
Stingray push.
-S
Witchboard
« Reply #22 on: December 14, 2005, 01:51:04 pm »
... drag.
Stingray push.
Urrr!  You confuse Witchboard... Witchboard smash!
I'm sure he uses the casters on the back of most cabs.. shouldn't be too much to pick up.
« Reply #23 on: December 14, 2005, 01:51:54 pm »
Not one of my cabs has casters on it.
Stingray
« Reply #24 on: December 14, 2005, 02:01:23 pm »
My Dynamo doesn't have casters. However, my house is tiled throughout. I put an old blanket on the floor and then stand the thing up on it. It slides very easy that way.
The fact remains that I can still get it in & out of the truck myself, and as previously stated, I'm a wimp.
-S
Witchboard
« Reply #25 on: December 14, 2005, 02:11:17 pm »
Well then, I stand corrected.   :police:
Stingray
« Reply #26 on: December 14, 2005, 02:13:01 pm »
Well the other upright that I have does have casters, so you're still battin' .500 :)
-S
« Reply #27 on: December 14, 2005, 02:13:51 pm »
He's 0-4 with me.
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
« Reply #28 on: December 14, 2005, 03:23:12 pm »
I'm surprised that you have the engery/motivation to move a Dynamo.
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
Stingray
« Reply #29 on: December 14, 2005, 03:48:05 pm »
New arcade cab out in the back of the truck. I can't play it until I get in inside, upright, and plugged in. The only thing that would motivate me more would be if it were full of beer and strippers.
-S
Ed_McCarron
« Reply #30 on: December 14, 2005, 03:57:27 pm »
It would weigh more then.  Or, gravity might be stronger.  Ask Bosss7.
missioncontrol
« Reply #31 on: December 14, 2005, 04:01:06 pm »
Stingray
« Reply #32 on: December 14, 2005, 04:12:22 pm »
If it were full of strippers, I'd make them get out and carry it for me. :)
-S
Ed_McCarron
« Reply #33 on: December 14, 2005, 05:13:49 pm »
ha cross posting makes it funnier
You just know that someone out there is reading it and going "WTF?  Where does he get this from?"
nostrebor
  • SHOCKING!!
« Reply #34 on: December 14, 2005, 05:20:01 pm »
U-Haul trailers weigh 17 metric tons and tow like --I'm attempting to get by the auto-censor and should be beaten after I re-read the rules--.
 And no! I am not bitter!
Zakk
  • Last login:March 04, 2026, 08:31:59 pm
« Reply #35 on: December 14, 2005, 06:17:54 pm »
I thought this was going to be a joke thread.  Like "ironing board wing on a civic!"
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #36 on: December 14, 2005, 09:40:38 pm »
-S
So you lied about your love for bacon then, because any bacon-lover worth a darn would have the strippers outfitted with bacon bikini's.
In a former job-life, I used to rent trailers, and I've got a buddy who happens to own a trailer rental yard.  You probably can't get a temporary hitch for that thing, but you should be okay with U-haul's smallest trailer (which should fit a cab or pin, but DON'T do the ass-fault removal with it).  He said he believes most of their trailers are all-metal, making them heavier than most of his, but with the small amount of weight you're talking about, you should be fine.
« Reply #37 on: December 14, 2005, 09:49:06 pm »
Eh... with that answer, I think I'll pass on the whole thing.  I'd rather not toe the line when it comes to my transmission.  I'll be done paying for this thing in 4 months and it could last me another 3 years at least.
DrewKaree
  • HAH! Nice one!
« Reply #38 on: December 14, 2005, 09:52:06 pm »
I think they have vans you can rent for cheap.  If not, just head to Home Depot to rent one of their trucks.  You might have to buy a few 2x4's, but it's cheap
« Reply #39 on: December 14, 2005, 09:58:05 pm »
What would a Uhaul place do, though, if you rented their truck to haul broken asphalt?  Would there be potential damage issues?
And UHaul is horribly unreliable... every time I try to rent a vehicle from UHaul they don't actually HAVE it when they say it will be there.
