Author Topic: Keywiz +5v connection  (Read 1807 times)
scorpio1968
  • Last login:April 12, 2007, 03:38:41 pm
« on: December 13, 2005, 01:31:46 pm »
Does anybody know what the +5V connection on the Keywiz encoders is used for?
thanks
Scorpio
Tiger-Heli
    • Tiger-Heli
Re: Keywiz +5v connection
« Reply #1 on: December 13, 2005, 02:13:00 pm »
Generally, power to an Opti-PAC in serial mode (don't think the USB Opti-PAC needs it), also possibly LED's (with a dropping resistor) for coin door lights, etc.
scorpio1968
« Reply #2 on: December 13, 2005, 02:19:20 pm »
thanks! No chance it could be used to power illuminated push buttons?
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: December 13, 2005, 02:37:25 pm »
Low-current LED illuminated push buttons (one or two) - sure.
Incandescent lamp or all the LED's on the entire illuminated button CP - probably not.
But RandyT would be a better person to ask.
Havok
« Reply #4 on: December 13, 2005, 04:12:41 pm »
The optical joysticks require 5 volts to work - that is most likely what it was really designed for. For all the blinky lights, you want a LED Wiz...
    • GroovyGameGear.com
« Reply #5 on: December 13, 2005, 10:16:45 pm »
Everyone is pretty much correct on this one.
10 or so LEDs with proper resistors, Optical Joysticks, Serial interfaces, etc... are all ok to use with the 5v connection.
Just don't try to do too much of that list from that little connection.  If you need to do more than one of these things, tap the PCs 5v power instead.
rally9x
  • Last login:July 21, 2008, 03:35:55 pm
« Reply #6 on: February 02, 2006, 05:26:58 pm »
I figured it would be better to bump this old thread then start a new one. But how many p360's could you safely power off of one line, only one? two? how about 4? Do all of the keywizs have a 5v (I almost didn't buy one because I don't see it as a feature on the groovy games list).
« Reply #7 on: February 02, 2006, 06:08:37 pm »
I think you could get away with 4 ok.  All of the Ecos have the line available.  If you want the MAX to have it available at one of the terminals, you can add a drop of solder to bridge the 5v enable pad on the board, or request that we do it for you in the comments box at checkout time.
rally9x
« Reply #8 on: February 02, 2006, 07:30:25 pm »
Ok thanks, I'll probably just pick up two eco's then.
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: February 03, 2006, 08:20:04 am »
For two cabs???
(If you have a single cab, I doubt you have two PS/2 ports, so you might want to look at an Eco and a GP-Wiz instead!)
